March 16, 2012, 05:34 |
problem in running icoFoam
valerio
Rep Power: 16 |
Good morning I'm dealing with a "simple" problem:
A cylindrical gemoetry where the fluid enters from two lateral openings and flows out from a small central tube. The reynolds has to be small (i'm doing some parametric study in the range [0:20] with Reynolds defined as: Re=UR/v v=cinematic viscosity, R= external radius of the geometry and U the inlet horizontal velocity (supposed constant). Well the boundary conditions are simply an exit (imposed pression value ) at the bottom of the small pipe and an inlet radial velocity. On the top I put a symetry condition icoFoam doesn"t converge in any case also for a Stokes case ( I removed the convective terms in the momentum equations)...so i think i'm doing something stupid with the mesh. Can someone help me? Thank you! here I copy the blockMeshDict (i copied and modified this file from an ancient discussion: http://www.cfd-online.com/Forums/ope...nder-mesh.html) HTML Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 1.7.1 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * *// //meshGenApp blockMesh; convertToMeters 0.017677664; vertices ( ( 1.0 -1.0 -15.0) //0 ( 1.0 1.0 -15.0) ( -1.0 1.0 -15.0) ( -1.0 -1.0 -15.0) ( 1.0 -1.0 -2.0) //4 ( 1.0 1.0 -2.0) ( -1.0 1.0 -2.0) ( -1.0 -1.0 -2.0) ( 3.0 -3.0 0.0) //8 ( 3.0 3.0 0.0) ( -3.0 3.0 0.0) ( -3.0 -3.0 0.0) /*( 6.0 -6.0 0.0) //12 ( 6.0 6.0 0.0) ( -6.0 6.0 0.0) ( -6.0 -6.0 0.0) */ ( 40.0 -40.0 0.0) //12 ( 40.0 40.0 0.0) ( -40.0 40.0 0.0) ( -40.0 -40.0 0.0) ( 3.0 -3.0 20.0) //16 ( 3.0 3.0 20.0) ( -3.0 3.0 20.0) ( -3.0 -3.0 20.0) ( 40.0 -40.0 20.0) //20 ( 40.0 40.0 20.0) ( -40.0 40.0 20.0) ( -40.0 -40.0 20.0) /*( 6.0 -6.0 10.0) //20 ( 6.0 6.0 10.0) ( -6.0 6.0 10.0) ( -6.0 -6.0 10.0) */ ); blocks ( /*hex (0 1 2 3 4 5 6 7) (20 20 15) simpleGrading (1 1 1) // tubo hex (4 5 6 7 8 9 10 11) (20 20 10) simpleGrading (1 1 1) //raccordo hex (8 9 10 11 16 17 18 19) (20 20 50) simpleGrading (1 1 1) //raccordo riportato fino in alto hex (14 10 9 13 22 18 17 21) (30 20 50) simpleGrading (3 1 1) // hex (15 11 10 14 23 19 18 22) (30 20 50) simpleGrading (3 1 1)// hex (12 8 11 15 20 16 19 23) (30 20 50) simpleGrading (3 1 1) // hex (13 9 8 12 21 17 16 20) (30 20 50) simpleGrading (3 1 1) // */ hex (0 1 2 3 4 5 6 7) (40 40 80) simpleGrading (1 1 1) // tubo hex (4 5 6 7 8 9 10 11) (40 40 80) simpleGrading (1 1 1) //raccordo hex (8 9 10 11 16 17 18 19) (40 40 100) simpleGrading (1 1 1) //raccordo riportato fino in alto hex (14 10 9 13 22 18 17 21) (60 40 100) simpleGrading (0.2 1 1) // hex (15 11 10 14 23 19 18 22) (60 40 100) simpleGrading (0.2 1 1)// hex (12 8 11 15 20 16 19 23) (60 40 100) simpleGrading (0.2 1 1) // hex (13 9 8 12 21 17 16 20) (60 40 100) simpleGrading (0.2 1 1) // ); edges ( arc 2 1 (0.0 1.414214 -15.0) arc 1 0 (1.414214 0.0 -15.0) arc 0 3 (0.0 -1.414214 -15.0) arc 3 2 (-1.414214 0.0 -15.0) arc 6 5 (0.0 1.414214 -2.0) arc 5 4 (1.414214 0.0 -2.0) arc 4 7 (0.0 -1.414214 -2.0) arc 7 6 (-1.414214 0.0 -2.0) arc 10 9 (0.0 4.242641 0.0) arc 9 8 (4.242641 0.0 0.0) arc 8 11 (0.0 -4.242641 0.0) arc 11 10 (-4.242641 0.0 0.0) /*arc 14 13 (0.0 8.485281 0.0) arc 13 12 (8.485281 0.0 0.0) arc 12 15 (0.0 -8.485281 0.0) arc 15 14 (-8.485281 0.0 0.0) */ arc 14 13 (0.0 56.56856 0.0) arc 13 12 (56.56856 0.0 0.0) arc 12 15 (0.0 -56.56856 0.0) arc 15 14 (-56.56856 0.0 0.0) arc 18 17 (0.0 4.242641 20.0) arc 17 16 (4.242641 0.0 20.0) arc 16 19 (0.0 -4.242641 20.0) arc 19 18 (-4.242641 0.0 20.0) /*arc 22 21 (0.0 8.485281 10.0) arc 21 20 (8.485281 0.0 10.0) arc 20 23 (0.0 -8.485281 10.0) arc 23 22 (-8.485281 0.0 10.0) */ arc 22 21 (0.0 56.56856 20.0) arc 21 20 (56.56856 0.0 20.0) arc 20 23 (0.0 -56.56856 20.0) arc 23 22 (-56.56856 0.0 20.0) ); patches ( patch outlet ( (0 3 2 1) ) patch symmetry ( (16 17 18 19) (17 21 22 18) (18 22 23 19) (20 16 19 23) (20 21 17 16) ) patch inlet1 ( (14 15 23 22) ) patch inlet2 ( (13 12 20 21) ) patch walls ( (13 14 22 21) //lat walls (15 12 20 23) //lat walls (12 13 9 8) //bottom walls (13 14 10 9) //bottom walls (14 15 11 10) //bottom walls (15 12 8 11) //bottom walls (4 5 9 8) (5 6 10 9) (6 7 11 10) (7 4 8 11) (0 1 5 4) (1 2 6 5) (2 3 7 6) (3 0 4 7) ) ); mergePatchPairs ( ); HTML Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.1.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volVectorField; object U; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 1 -1 0 0 0 0]; internalField uniform (0 0 0); boundaryField { inlet1 { type fixedValue; value uniform (1. 0 0); } inlet2 { type fixedValue; value uniform (-1. 0 0); } walls { type fixedValue; value uniform (0 0 0); } symmetry { type zeroGradient; // type fixedValue; // value uniform (0 0 0); } outlet { type zeroGradient; } } // ************************************************************************* // HTML Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.1.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; object p; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 2 -2 0 0 0 0]; internalField uniform 0; boundaryField { inlet1 { type zeroGradient; } inlet2 { type zeroGradient; } symmetry { type zeroGradient; } walls { type zeroGradient; } outlet { type fixedValue; value uniform 0; } } // ************************************************************************* // |
March 17, 2012, 08:50 |
A_R
Rep Power: 16 |
plz copy your error firstly.
March 17, 2012, 09:01 |
valerio
Rep Power: 16 |
Im still working on that and now everything it's fine (I did everything again from 0) , thanks anyway Just to be "useful" for someone else I'll copy the mesh file I've done (and that now is working). The mesh size has to be "calibrated between the parts but everything it's fine now). HTML Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 1.7.1 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } /*-----------------------------------------------------*\ | ========= | | | \ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \ / O peration | Version: 1.3 | | \ / A nd | Web: http://www.openfoam.org | | \/ M anipulation | | \*-----------------------------------------------------*/ FoamFile { version 2.0; format ascii; root ""; case ""; instance ""; local ""; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * *// //meshGenApp blockMesh; convertToMeters 0.01; vertices ( ( 5.0 0 0) //0 ( 0 5.0 0) ( -5.0 0 0) ( 0 -5.0 0) ( 5.0 0 50.) //4 ( 0 5.0 50.) ( -5.0 0 50.) ( 0 -5.0 50.) ( 10. 0 0) //8 ( 0 10. 0) ( -10. 0 0) ( 0 -10. 0) ( 10. 0 50.) //12 ( 0 10. 50.) ( -10. 0 50.) ( 0 -10. 50.) ( 5.0 0 -50) //16 ( 0 5.0 -50) ( -5.0 0 -50) ( 0 -5.0 -50) ( 10. 0 -50) //20 ( 0 10. -50) ( -10. 0 -50) ( 0 -10. -50) ( 100. 0 0) //24 ( 0 100. 0) ( -100. 0 0) ( 0 -100. 0) ( 100. 0 50) //28 ( 0 100. 50) ( -100. 0 50) ( 0 -100. 50) ); blocks ( // pipe hex (0 1 2 3 4 5 6 7) (30 30 60) simpleGrading (1 1 2) hex (0 8 9 1 4 12 13 5) (30 30 60) simpleGrading (1 1 2) //1st quater hex (1 9 10 2 5 13 14 6) (30 30 60) simpleGrading (1 1 2) //2nd quater hex (2 10 11 3 6 14 15 7) (30 30 60) simpleGrading (1 1 2) //3rd quater hex (0 3 11 8 4 7 15 12) (30 30 60) simpleGrading (1 1 2) //4th quater //internal part of the domain hex (16 17 18 19 0 1 2 3) (30 30 60) simpleGrading (1 1 1) hex (16 20 21 17 0 8 9 1) (30 30 60) simpleGrading (1 1 1) //1st quater hex (17 21 22 18 1 9 10 2) (30 30 60) simpleGrading (1 1 1) //2nd quater hex (18 22 23 19 2 10 11 3) (30 30 60) simpleGrading (1 1 1) //3rd quater hex (16 19 23 20 0 3 11 8) (30 30 60) simpleGrading (1 1 1) //4th quater*/ // external part of the domain hex (8 24 25 9 12 28 29 13) (60 30 60) simpleGrading (7 1 2) //1st quater hex (9 25 26 10 13 29 30 14) (60 30 60) simpleGrading (7 1 2) //2nd quater hex (10 26 27 11 14 30 31 15) (60 30 60) simpleGrading (7 1 2) //3rd quater hex (11 27 24 8 15 31 28 12) (60 30 60) simpleGrading (7 1 2) //4th quater ); edges ( arc 8 9 (7.071067812 7.071067812 0.0) //1st quater arc 12 13 (7.071067812 7.071067812 50.0) //1st quater arc 20 21 (7.071067812 7.071067812 -50.0) //1st quater arc 9 10 (-7.071067812 7.071067812 0.0) //2nd quater arc 13 14 (-7.071067812 7.071067812 50.0) //2nd quater arc 21 22 (-7.071067812 7.071067812 -50.0) //2nd quater arc 10 11 (-7.071067812 -7.071067812 0.0) //3rd quater arc 14 15 (-7.071067812 -7.071067812 50.0) //3rd quater arc 22 23 (-7.071067812 -7.071067812 -50.0) //3rd quater arc 11 8 (7.071067812 -7.071067812 0.0) //4th quater arc 15 12 (7.071067812 -7.071067812 50.0) //4th quater arc 23 20 (7.071067812 -7.071067812 -50.0) //4th quater //******** EXTERNAL PART ********************************* arc 24 25 (70.71067812 70.71067812 0) //1st quater arc 28 29 (70.71067812 70.71067812 50.0) //1st quater arc 25 26 (-70.71067812 70.71067812 0.0) //2nd quater arc 29 30 (-70.71067812 70.71067812 50.0) //2nd quater arc 26 27 (-70.71067812 -70.71067812 0.0) //3rd quater arc 30 31 (-70.71067812 -70.71067812 50.0) //3rd quater arc 27 24 (70.71067812 -70.71067812 0.0) //4th quater arc 31 28 (70.71067812 -70.71067812 50.0) //4th quater ); boundary ( inlet1 { type patch; faces ( (24 25 29 28) ); } inlet2 { type patch; faces ( (26 27 31 30) ); } outlet { type patch; faces ( // exit of the pipe (16 17 18 19) (16 20 21 17) (17 21 22 18) (18 22 23 19) (19 23 20 16) ); } symmetry { type patch; faces ( // top faces (12 28 29 13) (13 29 30 14) (14 30 31 15) (12 15 31 28) (4 12 13 5) (5 13 14 6) (6 14 15 7) (4 7 15 12) (4 5 6 7) ); } fixedWalls { type wall; faces ( (25 26 30 29) //lat walls (27 24 28 31) (8 24 25 9) (9 25 26 10) (10 26 27 11) (11 27 24 8) // lateral draining pipe walls (9 8 20 21) (10 9 21 22) (11 10 22 23) (8 11 23 20) ); } ); mergePatchPairs ( ); |
IcoFoam Divergent Duct Simulation Problem | Technoyoungman | OpenFOAM Running, Solving & CFD | 1 | November 9, 2011 22:22 |
Problem running a parallel fluent job on local machine via mpd | highhopes | FLUENT | 0 | March 3, 2011 05:07 |
Problem running parallel. | Hernán | STAR-CCM+ | 1 | December 23, 2009 12:04 |
problem when running icoFoam on a complex shape flow field | wendywu | OpenFOAM | 1 | May 20, 2009 23:40 |
Problem with IcoFoam in parallel | skabilan | OpenFOAM Running, Solving & CFD | 12 | April 1, 2008 05:55 |
