MULESTemplates.C for compressible two phase flow
i have a two phase flow with variable density which change with pressure, temperature and chemical conversion!
look following step to derive a formulation for alphal1 1)ddt(rho) + div.(rho,U) = 0 and rho = rho1*alpha1+rho2*(1-alpha1)=(rho1-rho2)*alpha1+rho2 so: 2)ddt(rho_*alpha1) + div.(rho_,U) + ddt(rho2) + div.(rho2,U) = 0 and rho_ = rho1 - rho2 from MULESTemplates.C : fvScalarMatrix psiConvectionDiffusion ( fvm::ddt(rho, psi) + fv::gaussConvectionScheme<scalar>(mesh, phi, UDs).fvmDiv(phi, psi) //- fv::gaussLaplacianScheme<scalar, scalar>(mesh, CDs, snGrads) //.fvmLaplacian(Dpsif, psi) - fvm::Sp(Sp, psi) - Su ); and from incompressibleInterFoam or interPhaseChangeFoam : MULES::implicitSolve(oneField(), alphalpha1, phi, phiAlphalpha1, Sp, Su, 1, 0); can i use rho_ instead of oneField() in above structure? |
Yes you have to do it.
