-   OpenFOAM (http://www.cfd-online.com/Forums/openfoam/)
-   -   setFields not working (http://www.cfd-online.com/Forums/openfoam/92439-setfields-not-working.html)
dsanza September 14, 2011 08:14
Hi, i am simulating a water channel and got a problem with setFields.
when i run setfields, it doesn't report any mistakes.
Create time
Create mesh for time = 0
Reading setFieldsDict
Setting field default values
Setting internal values of volScalarField alpha1
Setting field region values
Adding cells with center within box (-100 -100 -100) (100 100 100)
End
however, it doesn't write any cel data in alpha1, it only changes the internalField value from 0 to 1
this is my setFieldsDict
defaultFieldValues
volScalarFieldValue alpha1 0
regions
boxToCell
box (-100 -100 -100) (100 100 100);
fieldValues
volScalarFieldValue alpha1 1
this is my alpha1 file before running setFields
dimensions [0 0 0 0 0 0 0];
my
internalField uniform 0;
boundaryField
wall
type zeroGradient;
pumpe1
type inletOutlet;
inletValue uniform 1;
value uniform 1;
pumpe2
type inletOutlet;
value uniform 1;
pumpe3
type inletOutlet;
value uniform 1;
pumpe4
type inletOutlet;
value uniform 1;
kanal1
type inletOutlet;
value uniform 1;
kanal2
type inletOutlet;
value uniform 1;
kanal3
type inletOutlet;
value uniform 1;
kanalrest
type inletOutlet;
value uniform 1;
atmosphere
type inletOutlet;
inletValue uniform 0;
value uniform 0;
it can't be something that difficult, it has to be a mistake i made! i have a similar test case working!
thank you very much for your help!
Diego
mgdenno September 14, 2011 08:45
Is your entire domain inside your setFields box?
dsanza September 14, 2011 09:00
i tried different boxes for setFields, none were working. now i just tried to define the corners of the boxes the other way arround and suddenly it worked! no idea why it shouldnt work the other way arround!
thank you
