Linking PETSc with OpenFoam
Old   September 15, 2011, 18:38
Question Linking PETSc with OpenFoam
Argen is on a distinguished road
I am trying to link a linear solver based on PETSc with OpenFoam. But I got some errors,
-L/opt/64/intel/fce/9.1.045/lib \ -L/home/s/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux64/lib64/ \ ./libP1Module.a -lfiniteVolume
-lOpenFOAM -liberty -ldl \ -lsvml -lifport -lifcore -limf -lm -lipgo -lirc -lgcc_s -lirc_s -ldl \ -lm -o /home/s/OpenFOAM/s-1.5/applications
/bin/linux64GccDPOpt/PPPP ./libP.a(mypetsc.o)(.text+0x3c): In function `linearsolvers_petsc_mp_solvelinearsystem_petsc_':
./libP.a(mypetsc.o)(.text+0x57):~/OpenFOAM/s/applications/solvers/p/mypetsc.F90:100: undefined reference to `mpi_comm_rank_'
./libP.a(mypetsc.o)(.text+0x72):~/OpenFOAM/s/applications/solvers/p/mypetsc.F90:101: undefined reference to `mpi_comm_size_'
./libP.a(mypetsc.o)(.text+0x8d):~/OpenFOAM/s/applications/solvers/p/mypetsc.F90:113: undefined reference to `matcreate_'
./libP.a(mypetsc.o)(.text+0xb2):~/OpenFOAM/s/applications/solvers/p/mypetsc.F90:114: undefined reference to `matsetsizes_'
./libP.a(mypetsc.o)(.text+0xc3):~/OpenFOAM/s/applications/solvers/p/mypetsc.F90:115: undefined reference to `matsetfromoptions_'
./libP.a(mypetsc.o)(.text+0xde):~/OpenFOAM/s/applications/solvers/p/mypetsc.F90:121: undefined reference to `matgetownershiprange_'
Any idea to solve it?
Argen is offline   Reply With Quote
Old   September 16, 2011, 07:17
David Boger
boger is on a distinguished road
Have you included the appropriate petsc header files in your code? Of course, you'll also then need to add the include path and library link in your Make/options file.
David A. Boger
boger is offline   Reply With Quote
Old   September 16, 2011, 10:45
Hi David,
Yes. I am sure that the appropriate PETSc header files were included. I tested it alone and found no problem. I also added libP.a generated from my entire code with one module based on petsc in the Make/options files. So, can you figure out what I should do next?
Thanks,
Ray
Old   September 16, 2011, 10:53
David Boger
Can you attach your Make/options file?
How did you "test it alone" if you cannot compile it?
David A. Boger
Old   September 16, 2011, 11:12
David Boger
Try something like this in your Make/options:
include $(RULES)/mplib$(WM_MPLIB)
EXE_INC = \
     $(PFLAGS) $(PINC) \
    -I$(PETSC_DIR)/include -I$(PETSC_DIR)/$(PETSC_ARCH)/include \
    -I$(LIB_SRC)/finiteVolume/lnInclude
EXE_LIBS = \
    -lfiniteVolume \
    -L$(PETSC_LIBDIR) -lpetsc -lpetscmat -lpetscvec -lpetscksp -lpetscdm
This is based on a slightly old version of PETSc. I think newer versions may have consolidated the libraries into one.
David A. Boger
Old   September 16, 2011, 11:14
The Make/options file is
EXE_INC = \
EXE_LIBS = \
./libP.a \
-lfiniteVolume
where libP.a is generated from my entire code. There is no problem to build libP.a.
I changed the linear-solver module using petsc to a program and then run it.
Old   September 16, 2011, 11:21
EXE_INC = \
     $(PFLAGS) $(PINC) \
EXE_LIBS = \
    -lfiniteVolume \
When the above modification is applied, I got a new error like,
-lm -o /home/s/OpenFOAM/s/applications/bin/linux64GccDPOpt/P1M1D
/usr/bin/ld: cannot find -lpetscmat
collect2: ld returned 1 exit status
make: *** [/home/s/OpenFOAM/s/applications/bin/linux64GccDPOpt/P1M1D] Error 1
Any idea about it?
Old   September 16, 2011, 11:39
David Boger
Yes, I forgot to mention that you are responsible for PETSC_DIR, PETSC_ARCH, and PETSCLIB_DIR to point to the directories where the include files and compiled libraries are stored. The PETSc documentation (e.g., the pdf file available on-line) discusses the definition of the first two of these and also discusses compiling PETSc as a shared library and linking to it.
David A. Boger
Old   September 16, 2011, 14:22
I already set the first two. But I have no idea about the third one. Can you let me know that?
Old   September 16, 2011, 14:42
David Boger
PETSCLIB_DIR should point to the directory where the compiled PETSc libraries (*.so files) are stored, consistent with the usual -L -l syntax for linking libraries. The answer will depend on how you configured and installed PETSc.
David A. Boger
Old   September 16, 2011, 15:06
First, PETSCLIB_DIR should be PETSC_LIBDIR mentioned before. Is it right?
In my case, two libaries (lib1.so and lib2.so) are stored in /home/s/PETSc/petsc-3.1-p8 which is the same as $PETSC_DIR. Well, after setting PETSC_LIBDIR, I got almost same error. The only difference is that
Before, it's /usr/bin/ld: cannot find -lpetscmat
Old   September 16, 2011, 15:29
David Boger
As I said, my example was from an older version of petsc, and they have since consolidated the libraries. Just shorten the list of libraries (the -l's) to the ones you have/need.
David A. Boger
Old   September 16, 2011, 15:41
Do you still remember which version you used?
Old   September 16, 2011, 15:54
David Boger
3.0.0-p8. But what's important to you is that the change notes for 3.1 mention that the configure was modified to compile a single library file, so just keep the -lpetsc and delete the other -lpet* entries I gave you.
David A. Boger
Old   September 16, 2011, 16:20
Yes, I think so. But even those -lpet* are deleted, the errors become
-lm -o /home/s/OpenFOAM/s/applications/bin/linux64GccDPOpt/PPP
./libP1Module.a(mypetsc.o)(.text+0xb2): In function `solvelinearsystem_petsc':
/~/OpenFOAM/s/applications/solvers/p/pp/mypetsc.F90:99: undefined reference to `petscinitialize_'
I wonder that you called some petsc subroutines inside OpenFOAM or called them in your own module linked with OF?
Anyway, is it due to something wrong with building libP.a from my code?
Old   September 16, 2011, 16:24
David Boger
Sorry, my only experience is calling PETSc directly from within OpenFOAM.
David A. Boger
Old   September 16, 2011, 16:36
That's fine. Thanks a lot.
Linking ALGLIB to OpenFOAM Phicau OpenFOAM Programming & Development 6 January 12, 2012 16:15
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 wyldckat OpenFOAM Announcements from Other Sources 3 September 8, 2010 06:25
Modified OpenFOAM Forum Structure and New Mailing-List pete Site News & Announcements 0 June 29, 2009 05:56
64bitrhel5 OF installation instructions mirko OpenFOAM Installation 2 August 12, 2008 18:07
OpenFOAM Debian packaging current status problems and TODOs oseen OpenFOAM Installation 9 August 26, 2007 13:50
