Acceleration and pressure on bodies dropped from height into water
Old   October 10, 2011, 15:54
Question Acceleration and pressure on bodies dropped from height into water
Kay J. Steen
entrophysics_kjs is on a distinguished road
Hello there, for the purpose of evaluation I hope somebody will give me some feedback on the suitability of OpenFOAM for the following type of calculations :
I am currently evaluating OpenFoam to check the possibility of using it for the following purpose:
The case consists of a solid body which are lowered into water. The body could be lowered by a wire, or dropped from a given height.
I will need a 6 dof solver with the possibility to constrain the body with a moving spring to simulate the flexibility of the wire. The spring should have high stiffness in tension and low stiffness in compression, (wire functionality).
I will also need a wave generator that is able to set up a 5th order Navier Stoke wave as a initial condition.
Desired results are acceleration and pressure on the solid body.
Is this possible to perform with OpenFoam?
Any feedback on this is appreciated.
entrophysics_kjs is offline   Reply With Quote
Old   October 17, 2011, 07:41
Peter Maday
mpeti is on a distinguished road
Hello
I have no experience with such problems but the following link may give you some hints for the problem:
http://dhastha.wordpress.com/2011/06...oam-pythonflu/
Peter
mpeti is offline   Reply With Quote
Old   October 18, 2011, 01:22
Kay J. Steen
Thank you, a step in the right direction.
Kay
body drop in water
Static vs Total Pressure Alfonso Ferrandez FLUENT 2 May 23, 2000 08:53
