Linking PETSc with OpenFoam
I am trying to link a linear solver based on PETSc with OpenFoam. But I got some errors,
-L/opt/64/intel/fce/9.1.045/lib \ -L/home/s/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux64/lib64/ \ ./libP1Module.a -lfiniteVolume -lOpenFOAM -liberty -ldl \ -lsvml -lifport -lifcore -limf -lm -lipgo -lirc -lgcc_s -lirc_s -ldl \ -lm -o /home/s/OpenFOAM/s-1.5/applications /bin/linux64GccDPOpt/PPPP ./libP.a(mypetsc.o)(.text+0x3c): In function `linearsolvers_petsc_mp_solvelinearsystem_petsc_': ./libP.a(mypetsc.o)(.text+0x57):~/OpenFOAM/s/applications/solvers/p/mypetsc.F90:100: undefined reference to `mpi_comm_rank_' ./libP.a(mypetsc.o)(.text+0x72):~/OpenFOAM/s/applications/solvers/p/mypetsc.F90:101: undefined reference to `mpi_comm_size_' ./libP.a(mypetsc.o)(.text+0x8d):~/OpenFOAM/s/applications/solvers/p/mypetsc.F90:113: undefined reference to `matcreate_' ./libP.a(mypetsc.o)(.text+0xb2):~/OpenFOAM/s/applications/solvers/p/mypetsc.F90:114: undefined reference to `matsetsizes_' ./libP.a(mypetsc.o)(.text+0xc3):~/OpenFOAM/s/applications/solvers/p/mypetsc.F90:115: undefined reference to `matsetfromoptions_' ./libP.a(mypetsc.o)(.text+0xde):~/OpenFOAM/s/applications/solvers/p/mypetsc.F90:121: undefined reference to `matgetownershiprange_' Any idea to solve it? |
Have you included the appropriate petsc header files in your code? Of course, you'll also then need to add the include path and library link in your Make/options file.
Yes. I am sure that the appropriate PETSc header files were included. I tested it alone and found no problem. I also added libP.a generated from my entire code with one module based on petsc in the Make/options files. So, can you figure out what I should do next? Thanks, Ray |
Can you attach your Make/options file?
How did you "test it alone" if you cannot compile it? |
Try something like this in your Make/options:
include $(RULES)/mplib$(WM_MPLIB) |
EXE_INC = \ -I$(LIB_SRC)/finiteVolume/lnInclude EXE_LIBS = \ ./libP.a \ -lfiniteVolume where libP.a is generated from my entire code. There is no problem to build libP.a. I changed the linear-solver module using petsc to a program and then run it. |
-lsvml -lifport -lifcore -limf -lm -lipgo -lirc -lgcc_s -lirc_s -ldl \ -lm -o /home/s/OpenFOAM/s/applications/bin/linux64GccDPOpt/P1M1D /usr/bin/ld: cannot find -lpetscmat collect2: ld returned 1 exit status make: *** [/home/s/OpenFOAM/s/applications/bin/linux64GccDPOpt/P1M1D] Error 1 Any idea about it? |
Yes, I forgot to mention that you are responsible for PETSC_DIR, PETSC_ARCH, and PETSCLIB_DIR to point to the directories where the include files and compiled libraries are stored. The PETSc documentation (e.g., the pdf file available on-line) discusses the definition of the first two of these and also discusses compiling PETSc as a shared library and linking to it.
PETSCLIB_DIR should point to the directory where the compiled PETSc libraries (*.so files) are stored, consistent with the usual -L -l syntax for linking libraries. The answer will depend on how you configured and installed PETSc.
In my case, two libaries (lib1.so and lib2.so) are stored in /home/s/PETSc/petsc-3.1-p8 which is the same as $PETSC_DIR. Well, after setting PETSC_LIBDIR, I got almost same error. The only difference is that /usr/bin/ld: cannot find -lpetsc Before, it's /usr/bin/ld: cannot find -lpetscmat |
As I said, my example was from an older version of petsc, and they have since consolidated the libraries. Just shorten the list of libraries (the -l's) to the ones you have/need.
3.0.0-p8. But what's important to you is that the change notes for 3.1 mention that the configure was modified to compile a single library file, so just keep the -lpetsc and delete the other -lpet* entries I gave you.
-lm -o /home/s/OpenFOAM/s/applications/bin/linux64GccDPOpt/PPP ./libP1Module.a(mypetsc.o)(.text+0xb2): In function `solvelinearsystem_petsc': /~/OpenFOAM/s/applications/solvers/p/pp/mypetsc.F90:99: undefined reference to `petscinitialize_' ... I wonder that you called some petsc subroutines inside OpenFOAM or called them in your own module linked with OF? Anyway, is it due to something wrong with building libP.a from my code? |
Sorry, my only experience is calling PETSc directly from within OpenFOAM.
