How to create a new cyclic BC
Old   February 9, 2012, 08:01
Default How to create a new cyclic BC
Gregory N de Boer
gregdB is on a distinguished road
Hi all,
I have been attempting to replicate the fan BC so that I can create my own derived type of cyclic BC. All has been going OK by following:
http://openfoamwiki.net/index.php/Ho...dary_condition
But I have a problem. There is no entry for fixedJumpFvPatchField.C or equivalent in $FOAM_SRC/finiteVolume/Make/files ? How can this be copied and how can it be complied in the first place without an entry here?
Any help would be very much appreciated.
Cheers,
Greg
gregdB is offline   Reply With Quote
Old   February 9, 2012, 10:56
Steven van Haren
stevenvanharen is on a distinguished road
I am confused, where did you find this C-file? Why do you expect an entry for this in the Make-file?
stevenvanharen is offline   Reply With Quote
Old   February 9, 2012, 12:00
Gregory N de Boer
The C and H files for fixedJump are found in $FOAM_SRC/finiteVolume/fields/fvPatchFields/derived/fixedJump
To create a BC I copy a similar one from $FOAM_SRC/finiteVolume/fields/fvPatchFields/... and after changing the names then look-up from $FOAM_SRC/finiteVolume/Make/files for the correct entries needed to compile it. All BC's eg fan, jumpCyclic etc have entries in here so that they can be copied yet fixedJump does not?
Old   February 10, 2012, 07:22
Steven van Haren
Ah ok, sorry, was looking in the wrong OF version.
fixedJump does not have an entry since it is not a boundary condition. It is just a parent-class for the fan boundary condition. It will be compiled since it is included in the fan b.c. files.
Maybe try to base your new b.c. on the fan b.c.?
Old   February 10, 2012, 07:56
Gregory N de Boer
I see, unfortunately I need to change jumpCyclic, fixedJump and fan bc so that I can get what I need. If I change fixedJump as well as fan and then include all the files when compiling fan hopefully that will work?
Old   February 10, 2012, 08:19
Steven van Haren
Yes, that will work. But make sure you include the updated files and not the files from the lnInclude folder.
Old   February 10, 2012, 09:40
Gregory N de Boer
Thanks, it complies and runs. All I now need to do now is change the code! Cheers, Greg
cyclic boundaries, openfoam 2.0.x
how to set periodic boundary conditions Ganesh FLUENT 15 November 18, 2020 06:09
[blockMesh] Include list of points Hikachu OpenFOAM Meshing & Mesh Conversion 0 June 20, 2011 09:03
Actuator disk model audrich FLUENT 0 September 21, 2009 07:06
Where's the singularity/mesh flaw? audrich FLUENT 3 August 4, 2009 01:07
