How to define Boundary Conditions in heat Transfer ??
Old   July 16, 2011, 15:07
Default How to define Boundary Conditions in heat Transfer ??
almir is on a distinguished road
hi,
i want to make a research on natural convection, for that i have to use OpenFoam.
As solver my plan is to use buoyantSimpleFoam or buoyantSimpleRadiationFoam (if you know a better solver please tell me ;-) )
My geometry is a cylinder (1m long, diameter 5cm) which has a temperature of 70°C, the room in which the the cylinder is have a temperature of 20 °C. I have the geometry edited in BlockMeshDict as 2-Dmodel, i also have the model in a 3-D model meshed by Netgen.
The geometry you can see in the picture.
I want to get by OpenFoam results for the velocity, i have measured in a test rig that the velocity is u = 0,05m/s to 0,25 m/s.
My problem now is how i can define the boundary conditions.
i donīt know which value alphat, epsilon, k, mut and omega from the buoyantSimpleFoam-tutorial should have?
or which value alphat, epsilon, G, k, and mut from the buoyantSimpleRadiationFoam-tutorial should have?
if i use the tutorials, and edit the temperature to 20°C and 70°C and the pressure to 1bar, i always get a Error message.
Can somebody help me?
thanks and greets
almir
almir is offline   Reply With Quote
Old   July 18, 2011, 02:33
Nima Samkhaniani
nimasam is on a distinguished road
hi
1) if u access to fluent documentation you can find how to calculate first approximation for k-epsilon
or here :
http://www.cfd-online.com/Forums/ope...lon-model.html
2) as i remember mut and alphat can be set calculated
3 ) buoyantSimpleRadiationFoam-tutorial :
http://www.google.com/url?sa=t&sourc...zGzXIw&cad=rja
nimasam is offline   Reply With Quote
Old   September 27, 2011, 02:10
Default hiiiiii
Jignesh
jignesh_thaker2007 is on a distinguished road
Send a message via Yahoo to jignesh_thaker2007
hi,
i want to make a project on openFoam. i solved cavity problem for isothermal flow now i want to go for nonisothermal problem for cavity laminar flow it means natural convection flow.so as solver what r the modification require in icoFoam solver.
i donīt know which value alphat, epsilon, k, mut and omega from the buoyantSimpleFoam-tutorial should have? so i m so confused
thanks and greets
jignesh
jignesh_thaker2007 is offline   Reply With Quote
Old   September 27, 2011, 02:20
Bernhard
Bernhard is on a distinguished road
Please post your questions not in multiple topics, that is confusing:
http://www.cfd-online.com/Forums/ope...onvection.html
Bernhard is offline   Reply With Quote
Implementation of boundary conditions for FVM Tom Main CFD Forum 7 August 26, 2014 05:58
Heat Transfer boundary conditions for engine coolant flow simulation rajuks Main CFD Forum 0 February 15, 2010 09:04
Heat Transfer Boundary Conditions yingying FLUENT 0 December 8, 2009 16:44
Missing math.h header Travis FLUENT 4 January 15, 2009 11:48
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 12:24
