Pressure definition in OF 2.0.1 (simpleFoam etc.)
Old   September 27, 2011, 12:46
Default Pressure definition in OF 2.0.1 (simpleFoam etc.)
Miles
miles_davis is on a distinguished road
Does anyone know what is pressure in OF2.0.1 for solver like SimpleFOAM?
I have read that in previous versions of the code it was in fact Pstatic-rho*g*h, than in another version it was just Pstatic/rho. What is the actual statement for OF 2.0.1?
The source of my question is simple: Consider a water box. you model inlet and outlet.
If the outlet is at the bottom (i.e.altitude is lower than the inlet) what BC do I define for pressure at the outlet???
If P stands for p/rho, I have to calculate the hydrostatic pressure at he bottom.
If p stands fo p/rho-g*h: I just have to put P=0.
Thanks for you help.
Regards,
Miles
P.S;: I have found post on the subject but it was for older version as OF 1.7
miles_davis is offline   Reply With Quote
Old   September 28, 2011, 15:25
Daniel P. Combest
chegdan will become famous soon enoughchegdan will become famous soon enough
Originally Posted by miles_davis View Post
Regards,
Miles
Miles,
For simpleFoam it is a relative pressure related to a reference value. If you look at the creatFields.H and Peqn.H in the simpleFoam solver that might help.
Dan
chegdan is offline   Reply With Quote
Old   September 28, 2011, 17:16
Vesselin Krastev
vkrastev is on a distinguished road
You are confusing compressible and incompressible solvers. As far as I know, all the incompressible solvers in OF (like simpleFoam or pisoFoam), in all the releases (at least from the 1.6 to the 2.0.1, including the -dev/-ext ones), solve for the kinematic relative pressure, i. e. for p/rho (if rho is a constant, defining the pressure source term in the momentum equation as -1/rho*grad(p) or as -grad(p/rho) is equivalent). For the compressible solvers, things are not so established between different releases (honestly i really can't understand why), as for example in the 1.6 release a solver like rhoSimpleFoam assumes the static pressure as the dependent variable, while in the 1.7.0/1/x (and I think also in the 2.0.0/1/x family) the dependent variable is p-rho*g*h.
Hope this helps
V.
vkrastev is offline   Reply With Quote
Old   September 29, 2011, 18:35
Miles
thanks for your replies
regards
miles
pressure in incompressible solvers e.g. simpleFoam chrizzl OpenFOAM Running, Solving & CFD 13 March 28, 2017 05:49
BC settings to expand pressure on atmosphere - simpleFoam / totalPressure sErik OpenFOAM Running, Solving & CFD 1 June 15, 2011 02:49
Setup/monitor points of pressure and force coefficients siw CFX 3 October 22, 2010 06:07
Neumann pressure BC and velocity field Antech Main CFD Forum 0 April 25, 2006 02:15
Pressure definition CFX Begineer CFX 4 October 18, 2002 11:31
