August 26, 2015, 10:27 |
Error while adding side force Coef.
#21 | |
ASHISH
Rep Power: 11 |
Hi With ref to your post regarding error in side force Coef I am sending this mail. Following is the error that occur after wmake libso ************************************************** ********** wmakeLnInclude: linking include files to ./lnInclude Making dependency list for source file forceDirCoeffs/forceDirCoeffs.C could not open file writer.H for source file forceDirCoeffs/forceDirCoeffs.C due to No such file or directory Making dependency list for source file forceDirCoeffs/forceDirCoeffsFunctionObject.C could not open file writer.H for source file forceDirCoeffs/forceDirCoeffsFunctionObject.C due to No such file or directory SOURCE=forceDirCoeffs/forceDirCoeffs.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/opt/openfoam230/src/finiteVolume/lnInclude -I/opt/openfoam230/src/meshTools/lnInclude -I/opt/openfoam230/src/sampling/lnInclude -I/opt/openfoam230/src/transportModels -I/opt/openfoam230/src/turbulenceModels -I/opt/openfoam230/src/turbulenceModels/LES/LESdeltas/lnInclude -I/opt/openfoam230/src/thermophysicalModels/basic/lnInclude -I/opt/openfoam230/src/postProcessing/functionObjects/forces/lnInclude -IlnInclude -I. -I/opt/openfoam230/src/OpenFOAM/lnInclude -I/opt/openfoam230/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/forceDirCoeffs.o In file included from forceDirCoeffs/forceDirCoeffs.H:96:0, from forceDirCoeffs/forceDirCoeffs.C:26: /opt/openfoam230/src/postProcessing/functionObjects/forces/lnInclude/forces.H:125:20: fatal error: writer.H: No such file or directory compilation terminated. make: *** [Make/linux64GccDPOpt/forceDirCoeffs.o] Error 1 ************************************************** *************** we have also tried wclean and removed all dep files still same error occurs. Our version No is 2.3.0 Kindly help for the same. |
August 26, 2015, 11:13 |
Error persists
#22 | |
Sukratu Barve
Rep Power: 17 |
We get the same error. Unfortunately,, it persists even after doing wclean and
after removing all the .dep files (our wclean does not seem to remove those; only a directory ends up getting removed) Sincerely, S Quote:
August 26, 2015, 11:44 |
#23 |
Hassan Kassem
Rep Power: 17 |
I just tried to compile it using OpenFOAM-2.2.x and OpenFOAM-2.3.x and it works without any error.
Here are the steps based on the README file which I followed: Code:
git clone git://github.com/wyldckat/forceDirCoeffs.git cd forceDirCoeffs git checkout of22x wmake libso forceDirCoeffs |
August 26, 2015, 11:58 |
#24 |
Sukratu Barve
Rep Power: 17 |
I will check if that README file has been followed. I do not think it has been.
October 15, 2017, 15:50 |
side forces in of versions 4.1, 5.1.
#25 |
Swapnil Mali
Hi people,
I am trying to add side forces patch on Openfoam versions 3.1, 4.1 and 5.1, however following the earlier steps to verbatim have not solved my problem. any suggestions? I am attaching a image for reference. regards, Swapnil. |
October 17, 2017, 03:12 |
compiled side force directory for OF5
#26 |
Swapnil Mali
I have compiled force dir files for version 5 of openfoam, however these have given me some errors while compling using wmake. I am guessing it is more of a white space or tab issue. I tried fixing it, but no luck. If anybody here can take a loog at these files and let me know the issues. that would be a great help.
regards, Swapnil Mali Savitribai Phule Pune University. forceDirCoeffs(of5.1).tar.gz Last edited by Swapnilmali1988; October 18, 2017 at 12:12. |
Force can not converge | colopolo | CFX | 13 | October 4, 2011 22:03 |
How to measure side force and yawing moment | firda | FLUENT | 0 | November 3, 2010 02:33 |
[blockMesh] BlockMeshmergePatchPairs | hjasak | OpenFOAM Meshing & Mesh Conversion | 11 | August 15, 2008 07:36 |
CFX Solver Memory Error | mike | CFX | 1 | March 19, 2008 07:22 |
[Commercial meshers] Converting meshes that includes interfaces | ham | OpenFOAM Meshing & Mesh Conversion | 29 | January 8, 2007 08:58 |
