error in calculating grad field. possible bug?
Old   October 1, 2011, 23:01
Default error in calculating grad field. possible bug?
doubtsincfd is on a distinguished road
In the file write.H in laplacianFoam solver, I simply add a line
gradT.write();
recompile and run the tutorial for laplacianFoam. (the flange tutorial)
In file gradT: zeroGradient for all patches!
In files gradTx,gradTy,gradTz: non-zero values for gradTx, gradTy and gradTz on patches where zeroGradient is specified! and non zero for other patches too, though the gradT file shows zeroGradient.
Whats wrong and with whom? (me or OF)
doubtsincfd is offline   Reply With Quote
Old   October 2, 2011, 04:26
Nima Samkhaniani
nimasam is on a distinguished road
im not sure but i think when you fixed zeroGradient at patch it will consider the patch normal gradient zero so the gradient of the patch in the other directions are non- zero
nimasam is offline   Reply With Quote
Old   October 2, 2011, 13:21
what about patches with a fixedValue bc? Why does the gradient come out as zero?
Old   October 2, 2011, 14:06
Nima Samkhaniani
as you said the value on patch is fixed so tangential gradients should be zero but normal gradient can be non zero!
Old   October 3, 2011, 06:06
Hrvoje Jasak
hjasak will become famous soon enough
Not sure what your problem is: the gradient of T at a boundary will be a vector and only a surface-normal component of this gradient is specified in the T boundary conditions. The other two components will be non-zero, due to eg. tangential component of the gradient and picked up from the cell inside of the domain next to the patch. The code that does this is:
template<class Type>
void gaussGrad<Type>::correctBoundaryConditions
const GeometricField<Type, fvPatchField, volMesh>& vsf,
GeometricField
typename outerProduct<vector, Type>::type, fvPatchField, volMesh
>& gGrad
forAll(vsf.boundaryField(), patchi)
if (!vsf.boundaryField()[patchi].coupled())
vectorField n =
vsf.mesh().Sf().boundaryField()[patchi]
/vsf.mesh().magSf().boundaryField()[patchi];
gGrad.boundaryField()[patchi] += n *
vsf.boundaryField()[patchi].snGrad()
- (n & gGrad.boundaryField()[patchi])
All is fine,
Hrv
Hrvoje Jasak
Providing commercial FOAM/OpenFOAM and CFD Consulting: http://wikki.co.uk
hjasak is offline   Reply With Quote
problems after decomposing for running alessio.nz OpenFOAM 7 March 5, 2021 04:49
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 06:51
Problems calculating field gh with interFoam cricke OpenFOAM Running, Solving & CFD 0 December 10, 2007 07:17
How to update polyPatchbs localPoints liu OpenFOAM Running, Solving & CFD 6 December 30, 2005 17:27
