problem of kappat in buoyantBoussinesqSimpleFoam
Old   October 2, 2011, 05:45
Default problem of kappat in buoyantBoussinesqSimpleFoam
Jignesh
jignesh_thaker2007 is on a distinguished road
Send a message via Yahoo to jignesh_thaker2007
hi everyone
i solved problem for 2D laminar & nonisothermal cavity flow problem for nondimensional it means i took dimension for nu =1, pr=1,beta=1 & i took reftemp=0.
my right wall temp=0 & left wall temp=1 it means left wall is heated.another r insulated.
so now i only varies gravitational constant "g" so for that problem i compare my result with bench mark result. it match with benchmark result.
it means i varies gresoff number with "g".
but when i took the pr number= 0.5 or 0.1 or say less than 1 and i solved the problem but it cant match with benchmark result so i very much confused in property kappat.
so give me advice if i will solve the problem for different pr number than what r the properties will change?
and tel me also what is the roll of kappat because i saw the code but i cant understand.
thanx
jignesh
jignesh_thaker2007 is offline   Reply With Quote
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 04:43
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 05:59
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 06:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 14:52
