Home > Forums > OpenFOAM
MPI comunication wrong after use of gather/scatter
Old   October 5, 2011, 05:09
Default MPI comunication wrong after use of gather/scatter
matteo lombardi
matteoL is on a distinguished road
I have implemented my own version of a mesh motion solver that, when run in parallel, it needs to exchange data with other partitions.
To do so I have used the gather/scatter and IPStream/OPStream functions available in OF.
The new library seems to work fine.
The problem is that now when i run my code in parallel the fluid solver doesn't work anymore!
The residual of U and P solver are very high and looking at the solution (see attached image) it seems like there is no more comunications between processors since there is a very high unphysical boundary layer where the different partitions touch each other.
The cube shoew in the picture has been decomposed in 3 subdomain with simple (1 1 3) scheme. The correct result should be a small value everywhere but on the top (cavity problem, initial time step).
Any idea how can I have managed to mess up with the MPI comunications in the linear solvers? I haven't touched them at all and my own library I have used only OF MPI functions (i.e. gather/scatter/PStream).
matteoL is offline   Reply With Quote
Old   October 10, 2011, 13:19
Default Gather/scatter is not the problem... mesh.update() is the trigger..
matteo lombardi
After some more analysis, I have discovered that the problem is not linked at all to gather/scatter...
In fact I have no problem If I use my mesh motion solver as long as i don' t call for mesh.update().
mesh.update() call for my own version of curPoints() anbd solve().
Even If i set solve() to do nothing and curPoitns() just to give back the current mesh points without modifiyng them, I still have the problem described above in parallel..
How can this be possible? What else is called in mesh.update that could create such a strange behaviour?
Thanks again,
Thread Tools
Trackbacks are On
Sgimpi pere OpenFOAM 27 September 24, 2011 07:57
udf error srihari FLUENT 0 February 9, 2009 10:00
Building OpenFOAM on IRIX lakeat OpenFOAM Installation 7 July 16, 2008 07:27
Error using LaunderGibsonRSTM on SGI ALTIX 4700 jaswi OpenFOAM 2 April 29, 2008 10:54
Is Testsuite on the way or not lakeat OpenFOAM Installation 6 April 28, 2008 11:12
