-   OpenFOAM (http://www.cfd-online.com/Forums/openfoam/)
-   -   Where can I find the doc of "compressibleLesInterFoam " (http://www.cfd-online.com/Forums/openfoam/93326-where-can-i-find-doc-compressiblelesinterfoam.html)
wwwwww_18 October 11, 2011 23:53
Hello, everybody
I'm a beginner of OpenFoam.
The behavior of the underwater discharge is very complicate. The quick expansion of the underwater arc generates shockwave. In the CFD view, it is a multi-flow problem(plasma bubble and compressible water). I think the standard solver "compressibleLesInterFoam" can simulate such problem. I can't get the document in "openfoamwiki.net". Would you please give a link to the doc/sample of the "compressibleLesInterFoam"?
Thank you very much
sabin.ceuca October 12, 2011 07:12
I think you're looking for "compressibleInterFoam" which can be found here: http://foam.sourceforge.net/docs/cpp...d26d1989a.html
You can use this solver with a LES turbulence model and have the "compressibleLesInterFoam" that you've mentioned.
Regards,
Sabin
wwwwww_18 October 12, 2011 20:10
Thank you very much!
