[Other] engineFoam new mesh problem
Like Tree3Likes
  • 2 Post By ayhan515
  • 1 Post By ayhan515
Old   October 12, 2011, 08:36
Arrow engineFoam new mesh problem
Ayhan Eses
ayhan515 is on a distinguished road
I run tutorial kivaTest case without fail.
I want to increase compression ratio value, like diesel engine, about 20.
I converted existent kiva mesh (otape17) to OpenFoam mesh(polymesh) with kivaToFoam command. It is ok no problem.
Then i converted OpenFoam mesh(polymesh) to a Fluent mesh(*.msh) with foamMeshToFluent command. It is ok no problem.
I deleted polyMesh folder which in constant folder.
This time I converted Fluent mesh(*.msh) to OpenFoam mesh(polymesh) to a by fluent3DMeshToFoam command. It is ok no problem.
I execute engineFoam command. it runs without problem.
kiva mesh ---->> OpenFoam mesh  ---->>  Fluent Mesh
 (otape17)              (polyMesh)      <<----      (*.msh)
                                          v
                                    engineFoam
                                   (works well)
After I changed the Fluent mesh then I convert new Fluent mesh to OpenFoam mesh(polymesh) to a by fluent3DMeshToFoam command. It is ok no problem.
 New Fluent Mesh   ---->> New OpenFoam mesh     xxxx    engineFoam
    (New.msh)                    (polyMesh)                               (Failed)
When I execute engineFoam command with new mesh. It gave this error message then exit.
Create engine time
Create mesh for time = -180
Selecting engineMesh layered
--> FOAM FATAL ERROR:
cannot find cylinderHead patch
    From function engineMesh::engineMesh(const IOobject& io)
    in file engineMesh/engineMesh/engineMesh.C at line 90.
FOAM exiting
I think problem caused from "cylinderHead patch".
In kivaToFoam command this problem solved by "Transfered xx faces from liner region to cylinder head"
Create time
Reading kiva grid from file "otape17"
Finished reading KIVA file
Transfered 500 faces from liner region to cylinder head
Default patch type set to empty
Writing polyMesh
Writing cell zoning info to file: "/home/ayhan/OpenFOAM/ayhan-2.0.1/run/tutorials/combustion/engineFoam/kivaTest/constant/region0/cellZoning"
End
I suppose solution in the below file
/opt/openfoam201/applications/utilities/mesh/conversion/kivaToFoam/readKivaGrid.H
// Transfer liner faces that are above the minimum cylinder-head z height
// into the cylinder-head region
if
    pFaces[LINER].size()
 && pFaces[LINER][0].size()
 && pFaces[CYLINDERHEAD].size()
 && pFaces[CYLINDERHEAD][0].size()
    scalar minz = GREAT;
    forAllConstIter(SLList<face>, pFaces[CYLINDERHEAD][0], iter)
        const face& pf = iter();
        forAll(pf, pfi)
            minz = min(minz, points[pf[pfi]].z());
    minz += SMALL;
    SLList<face> newLinerFaces;
    forAllConstIter(SLList<face>, pFaces[LINER][0], iter)
        scalar minfz = GREAT;
        forAll(pf, pfi)
            minfz = min(minfz, points[pf[pfi]].z());
        if (minfz > minz)
            pFaces[CYLINDERHEAD][0].append(pf);
        else
            newLinerFaces.append(pf);
    if (pFaces[LINER][0].size() != newLinerFaces.size())
        Info<< "Transfered " << pFaces[LINER][0].size() - newLinerFaces.size()
            << " faces from liner region to cylinder head" << endl;
        pFaces[LINER][0] = newLinerFaces;
    SLList<face> newCylinderHeadFaces;
        forAll(pf, pfi)
        if (minfz < zHeadMin)
            pFaces[LINER][0].append(pf);
        else
            newCylinderHeadFaces.append(pf);
    if (pFaces[CYLINDERHEAD][0].size() != newCylinderHeadFaces.size())
        Info<< "Transfered faces from cylinder-head region to linder" << endl;
        pFaces[CYLINDERHEAD][0] = newCylinderHeadFaces;
The question is how can i apply this solving. How can i transfer faces from liner region to cylinder head while i convert new fluent mesh to polyMesh.
Thanks in advance.
ayhan515 is offline   Reply With Quote
Old   October 18, 2011, 09:03
Arrow
Ayhan Eses
I used checkMesh command now. The output is below.
|  \\    /   O peration     | Version:  2.0.1                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.com                      |
Build  : 2.0.1-51f1de99a4bc
Exec   : checkMesh
Date   : Oct 18 2011
Time   : 15:46:26
Host   : ubuntu
PID    : 2780
Case   : /home/ayhan/OpenFOAM/ayhan-2.0.1/run/tutorials/combustion/engineFoam/kivaTest-fluent-11-10-2011
nProcs : 1
Create time
Create polyMesh for time = -180
Time = -180
Mesh stats
    faces:            85742
    internal faces:   79522
    cells:            27544
    boundary patches: 3
    point zones:      0
    face zones:       1
    cell zones:       1
Overall number of cells of each type:
    hexahedra:     27544
    prisms:        0
    wedges:        0
    pyramids:      0
    tet wedges:    0
    tetrahedra:    0
    polyhedra:     0
Checking topology...
    Boundary definition OK.
    Cell to face addressing OK.
    Point usage OK.
    Upper triangular ordering OK.
    Face vertices OK.
    Number of regions: 1 (OK).
Checking patch topology for multiply connected surfaces ...
    Patch               Faces    Points   Surface topology
    piston              1326     1400     ok (non-closed singly connected)
    liner               2710     2858     ok (non-closed singly connected)
    cylinderhead        2184     2260     ok (non-closed singly connected)
Checking geometry...
    Overall domain bounding box (-0.046 -0.0459845 -0.0089896) (0.046 0.0459845 0.20335)
    Mesh (non-empty, non-wedge) directions (1 1 1)
    Boundary openness (2.0111e-20 -4.34397e-19 6.81738e-20) OK.
    Max cell openness = 2.54332e-16 OK.
    Max aspect ratio = 68.0635 OK.
    Minumum face area = 4.94833e-07. Maximum face area = 8.23324e-05.  Face area magnitudes OK.
    Min volume = 6.14138e-10. Max volume = 2.72275e-07.  Total volume = 0.00126259.  Cell volumes OK.
    Mesh non-orthogonality Max: 86.981 average: 37.3601
   *Number of severely non-orthogonal faces: 5320.
    Non-orthogonality check OK.
  <<Writing 5320 non-orthogonal faces to set nonOrthoFaces
    Face pyramids OK.
    Max skewness = 3.89796 OK.
Mesh OK.
End
Exec   : engineFoam
Date   : Oct 18 2011
Time   : 15:47:49
Host   : ubuntu
PID    : 2985
nProcs : 1
Create engine time
FOAM exiting
I still get same error when i try to use engineFoam.
While i am writing this above message i noticed these
and
Then i changed cylinderhead to cylinderHead in boundary file of polyMesh folder.
Then now engineFoam is working. I am really shame on myself.
songwukong and kaveh19 like this.
Old   May 1, 2012, 04:29
Wang
enjoybitter is on a distinguished road
Good Experience!
Thanks for your sharing.
enjoybitter is offline   Reply With Quote
Old   August 9, 2015, 08:19
kaveh19 is on a distinguished road
Hi ayhan515,
thanks for your shearing.
how we can figure the volume of default geometry out and then know the compression ratio and clearance volume in kivaTest ?
thanks in advance.
kaveh19 is offline   Reply With Quote
Old   August 10, 2015, 05:37
Arrow
Ayhan Eses
Originally Posted by kaveh19 View Post
Hi ayhan515,
thanks in advance.
open a openfoam terminal and use these commands.
1
cd combustion/engineFoam/kivaTest
2
kivaToFoam
3
engineCompRatio
the output
|  \\    /   O peration     | Version:  2.4.0                                 |
Build  : 2.4.0-f0842aea0e77
Exec   : engineCompRatio
Date   : Aug 10 2015
Time   : 12:29:32
Host   : "ayhan-virtual-machine"
PID    : 3716
Case   : /home/ayhan/OpenFOAM/ayhan-2.4.0/run/tutorials/combustion/engineFoam/kivaTest
nProcs : 1
allowSystemOperations : Allowing user-supplied system call operations
Create engine time
deckHeight: 0.085639
piston position: 0
Using dynamicCode for functionObject timeStep at line 58 in "/home/ayhan/OpenFOAM/ayhan-2.4.0/run/tutorials/combustion/engineFoam/kivaTest/system/controlDict.functions.timeStep"
Creating new library in "dynamicCode/setDeltaT/platforms/linux64GccDPOpt/lib/libsetDeltaT_7bdeade1ab21a2b1d5fab42a96396cc9eda6b864.so"
Invoking "wmake -s libso /home/ayhan/OpenFOAM/ayhan-2.4.0/run/tutorials/combustion/engineFoam/kivaTest/dynamicCode/setDeltaT"
wmakeLnInclude: linking include files to ./lnInclude
Making dependency list for source file functionObjectTemplate.C
Making dependency list for source file FilterFunctionObjectTemplate.C
'/home/ayhan/OpenFOAM/ayhan-2.4.0/run/tutorials/combustion/engineFoam/kivaTest/dynamicCode/setDeltaT/../platforms/linux64GccDPOpt/lib/libsetDeltaT_7bdeade1ab21a2b1d5fab42a96396cc9eda6b864.so' is up to date.
CA = 0
deltaZ = 0.08423
clearance: 0.001409
Piston speed = 4.2115 m/s
Vmax = 0.000631297, Vmin = 7.15569e-05
Vmax/Vmin = 8.82231
End
kaveh19 likes this.
Old   August 10, 2015, 08:45
hi ayhan515,
I appreciate u.
yes ,I did ,but unfortunately I don't have any idea.
I have some question . would you mind helping me?
1) I want to run the bore*stroke=76*66 in different compression ratio e.g.,12 and 20. How can i create this C.R ?
2) When i run bore*stroke = 86*86 for KivaTest ,it runs until -5 not 60 . what's the reason?
thanks in advance.
Dynamic Mesh Problem. Tom Clark FLUENT 10 June 21, 2021 04:27
[snappyHexMesh] snappyHexMesh does not create any mesh except one for the reference cell Arman_N OpenFOAM Meshing & Mesh Conversion 1 May 20, 2019 17:16
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 18:57
[ICEM] ICEM Structured Mesh Problem OMJT ANSYS Meshing & Geometry 3 March 22, 2013 10:06
