heat transfer boussinesq
Dear Foam s,
please can anyone tell me how can I set a fixed heat flux on a wall using buoyantBoussinesqPimpleFoam? On the temperature file (T and T.org), if I set temperature as a fixedGradient, does it works? like grad (T) = qflux / k. Thanks for the attention. |
it depends ur k is fixed or not
1) if your k is fixed so use the fix Gradient for temperature 2) if your k is variable and change during simulation use groovyBC, to read k in each simulation and divide it into fixed qflux. (you can find in froum more ;) ) |
Thanks for the help.
I'm having problems with the time step of my case, when I set a fixedGradient to define heat flux ( k constant), if I increase the time step on controlDict, the results change too: temperature increases... Anyone know what am I doing wrong ? Thanks for the attention. |
