Home > Forums > OpenFOAM
createPatch and splitMesh problem
Old   October 19, 2011, 10:14
Default createPatch and splitMesh problem
supercommandodhruv
dhruv is on a distinguished road
Hi Foamers,
I am creating a geometry out of 5 different geometries. I used mergeMesh and stitchMesh to create the final geometry. Then, I create a faceSet using setSet utility. I want to assign a fan boundary condition to this faceSet. So,
1. I run the splitMesh, after updating my boundary file with two patches having 0 faces. (fan_master and fan_slave).
After running splitMesh, I have the following message
<<Number of duplicate (not baffle) faces found: 1. This might indicate a problem.
  <<Number of faces with non-consecutive shared points: 1. This might indicate a problem.
Writing mesh to 1
2. I run createPatch utility
Then, i run into this error
--> FOAM FATAL ERROR:
Face 7221101 specified in set fanFaces is not an external face of the mesh.
This application can only repatch existing boundary faces.
From function createPatch
in file createPatch.C at line 714.
I don't understand why this error is coming up. Can anyone help me?
dhruv is offline   Reply With Quote
Old   October 20, 2011, 06:03
Default Solved!!
supercommandodhruv
I got the solution to this problem. Apprantly, I did not make the correct entries in the createPatchDict.
Thanks,
Dhruv.
Originally Posted by dhruv View Post
Hi Foamers,
Writing mesh to 1
Old   April 24, 2012, 10:15
Default same problem
franzi_ is on a distinguished road
I find the same problems when running createPatch.
How did you solve the problem?
Or does anyone elso have a solution for that error message??
THANKS A LOT IN ADVANCE.
cheers Franzi
franzi_ is offline   Reply With Quote
Thread Tools
Trackbacks are On
Create internal faces after createPatch linnemann OpenFOAM Running, Solving & CFD 3 July 24, 2009 04:00
