Home > Forums > OpenFOAM
Offline installation
Old   October 27, 2011, 04:07
Default Offline installation
eric weddle is on a distinguished road
Hello there.
I'd like to know if there's anyway to install OpenFOAM Ubuntu package in a machine with no internet connection.
Thanks
eric weddle is offline   Reply With Quote
Old   October 27, 2011, 08:05
Bernhard
Bernhard is on a distinguished road
Did you try to copy the source pack from a USB disk?
Bernhard is offline   Reply With Quote
Old   October 27, 2011, 08:16
actually, i could only manage download the pack using the "apt-get install" command
Old   October 27, 2011, 08:21
Bernhard
You can download the source pack here:
http://www.openfoam.com/download/source.php
If you follow the instructions this should be no problem. Good luck
Old   October 27, 2011, 08:23
tanks a lot
Old   October 27, 2011, 12:42
Default APTonCD
Michael Ahlmann
danishdude is on a distinguished road
I recently had a similar predicament where I was trying to load OpenFOAM onto a machine that was not connected to the internet. The problem I ran into was that you can easily download and compile OpenFOAM source files, but getting dependences (Flex, Qt, etc...) is a pain in the neck. However, I found a really simple solution. This requires that you either have another machine that is connected to the internet and has the same version of Ubuntu installed (which was what I did) or you could use VirtualBox to virtually install a machine similar to the one you are trying to work with. There is a tool called APTonCD. Available at this link http://aptoncd.sourceforge.net/. You run the tool, and it allows you to create an APT repository from all the files currently installed via apt on your computer. This way, you merely load OpenFOAM on the machine that has the internet connection using APT, all dependencies are installed automatically, and then you use APTonCD to transfer this "custom" repository to the machine that does not have an internet connection. This is also a great way to transfer updates to the machine without an internet connection. Good Luck!
danishdude is offline   Reply With Quote
install, installation, installation of open foam, installation of openfoam
Thread Tools
Trackbacks are On
OpenFoam 2.0.0 installation Jan_Peters OpenFOAM Installation 86 April 27, 2012 05:32
CFX11 + Fortran compiler ? Mohan CFX 20 March 30, 2011 18:56
Installation problems indy OpenFOAM Installation 7 April 3, 2009 09:40
64bitrhel5 OF installation instructions mirko OpenFOAM Installation 2 August 12, 2008 18:07
Installation problems shellbell1999 OpenFOAM Installation 9 April 6, 2006 13:29
