-   OpenFOAM (http://www.cfd-online.com/Forums/openfoam/)
-   -   How to get a single value from a volScalarField including the dimension (http://www.cfd-online.com/Forums/openfoam/93820-how-get-single-value-volscalarfield-including-dimension.html)
safre October 27, 2011 07:17
Hello
I have problems getting the dimension correct when I am doing a simple sum. My equation is:
aveTSlab = aveTSlab + T[n];
where
aveTSlab is defined as
dimensionedScalar aveTSlab
"aveTSlab",
dimensionSet( 0, 0, 0, 1, 0, 0, 0),
scalar( 0)
and
volScalarField T
IOobject
"T",
runTime.timeName(),
mesh,
IOobject::MUST_READ
mesh
Both dimensions are defined correctly but when I take a single value T[n] it does not come with any dimension but the error is as:
--> FOAM FATAL ERROR:
LHS and RHS of + have different dimensions
dimensions : [0 0 0 1 0 0 0] + [0 0 0 0 0 0 0]
Please give advise how to get a single value from a volScalarField including the dimension.
tomislav_maric October 27, 2011 08:17
Originally Posted by safre (Post 329699)
Hello
and
volScalarField T
IOobject
"T",
runTime.timeName(),
mesh,
IOobject::MUST_READ
mesh
Nope, the dimensions of the volScalarField are not set correctly, try this:
volScalarField T
            IOobject
                    "T",
                    runTime.timeName(),
                    mesh,
                    IOobject::MUST_READ
            mesh,
            dimensionedScalar
                  "0", // a dummy name for the scalar
                  dimTemperature, // 00051 extern const dimensionSet dimTemperature; - preset global constant dimensionSet for the temperature
                  pTraits<scalar>::zero  // trait for the zero value of scalar
safre October 27, 2011 09:34
Thank you for your suggestion but it did not help me out.
In a way I still do not think it is a problem in the definition of T since that is only read from the ordinary Temperature file from my time directory and if I print out the complete T field the dimension is correct. The problem starts when I try to get one single value out of the field. I guess there is some command to do it another way than I am trying?
In fact what I really want to do is to take an average of a part of a volScalarField something like
TSlab = cmptAv(T(n0-nN));
or
TSlab = average(T(n0-nN));
including the dimension with n0 as the first value in a part of field T and nN being the last value in the part. Perhaps there is an even quicker solution to that problem?
Regards, Sam
tomislav_maric October 27, 2011 10:51
I think I've found the reason for this.
When you look in the following classes:
GeometricField<Type, PatchField, GeoMesh> -> DimensionedField< Type, GeoMesh> ->
Field< T > -> List < T > -> UList < T>, you will find that the access operator has not been redefined all the way since UList < T >:
T & operator[] (const label)
Wich will just return a scalar. So, each time you call T[label], you won't get a dimensionedScalar, but a scalar. To avoid this, you may define your own access operator [] for the GeometricField (this will probably mess up a lot of things), or you can deal with values...
meaning that this should help:
    scalar& aveTSlabVal = aveTSlab.value();
    aveTSlabVal = T[0];
You can even call
aveTSlab.val() = T[0]
if you like.
olesen October 28, 2011 02:41
Hello
where
"aveTSlab",
scalar( 0)
and
volScalarField T
IOobject
"T",
runTime.timeName(),
mesh,
IOobject::MUST_READ
mesh
Once you understand the volFields it will make more sense.
A volField is essentially a list of normal values that is augmented by a dimension. It is not a list of dimensioned values.
The means that any dimension checking is only done once for the entire field and not for each value.
In accordance with this, the
operator[]
will return the plain, undimensioned value. Thus the easiest and most efficient is to use the plain values directly
aveTSlab.value() += T[n];
If you really prefer to work with dimensioned values (and have dimensioning checking for each addition operation within the loop!!), try something like this:
aveTSlab += dimensionedScalar("T", T.dimensions(), T[n]);
For ease and generality, you will probably want to declare aveTSlab using the same dimensions as "T":
    "aveTSlab",
    T.dimensions(),
    pTraits<Scalar>::zero
safre October 28, 2011 03:44
Hello
Yes that works or even simpler using an ordinary double definition. It was just that I wanted to keep the dimensions in order to keep the dimension check in my coding.
The way I solved it now is to use a double inside the calculation and then do a nn.write(); to a correctly dimensioned volScalarFieldaveTz in the end as
aveTz[k]= some value without dimension
aveTz.write();
It works but it could have been more elegant.
Thanks for all your help, Sam
tomislav_maric October 28, 2011 04:41
Originally Posted by safre (Post 329841)
Hello
aveTz.write();
Dimension checks, based on this information, are kept only for the fields, since as soon as one wants to access a DimensionedField<Type, GeoMesh> element, a Type is returned, instead of Dimensioned<Type>. This is good when one assembles field equations and performs computations on fields, not on specific elements. This means that +,/,* operators on GeometricField have built in dimension checks.
What you are describing here is an addition of value, not a complex equation involving fields: OpenFOAM is all about working with fields. :) I'm doing a lot of cell local explicit computation myself and the farther I get from manipulating the fields using their operators and numerics that is already there, the more problems I get into.
Anyway, good luck. :)
calim_cfd March 1, 2012 10:41
hihi!
within this scope.. can any1 please tell me what am i missing?
i wanna change the dimensions of wallHeatFlux so i can operate with T.
I figured this should work:
volScalarField wallHeatFlux(wallHeatFluxheader, mesh);
        wallHF += dimensionedScalar("wallHF", T.dimensions(), wallHeatFlux);
i get the error:
conVh.C: In function ‘int main(int, char**)’:
conVh.C:166:3: error: ‘wallHF’ was not declared in this scope
thanks in advance!
laurensvd March 1, 2012 10:50
You never defined what type wallHF is, you need to add volScalarField in front of wallHF +=...
what you can also do is reset the dimensions of wallHeatFlux to something different like so:
wallHeatFlux.dimensions().reset(T.dimensions());
calim_cfd March 1, 2012 14:45
hi lauren!
Thanks a lot for replying..
but i guess the units error im getting comes from the sum (T - 300)
I guess i gotta set dimension to that 300... i've tried to find sth on the forums but so far nothing.. any ideas?
i tried a few syntax too but few would work... this one works:
scalar Tam = 300; and i set the sum to (T- Tam) .. the app compiles but the error is there.. ill keep digging :(
thanks once again!
EDIT:
i guess i got it..:
dimensionedScalar Tam ("Tam", dimensionSet(0, 0, 0, 1, 0, 0, 0),300.0);
now im getting other erros,
but again TY!!!!!
sfigato March 25, 2013 05:33
Hi Foamers,
I would like to implement a new cavitation solver in openFoam! I added a transport equation for mass fraction where I need to compare my local pressure (p) with a scalar experimental value pEq!
During the compiling of the code I got a dimension error!
Can anyone help me to fix it?
Here is the transport equation code:
// Solve Mass Fraction Equation for the Gas Air (undissolved)
#include "sourceTerms.H"
//Scalar Transport Equation for Mass Fraction
if (pEq > p) //p)
fvScalarMatrix f4Eqn
fvm::ddt(rho, f4)
+ fvm::div(rhoPhi /*phi*/, f4)
- fvm::laplacian(Gamma4,f4)
//+ fvm::Sp(AaL,f4)
+ fvm::Sp(AdL,f4)
f4Eqn.relax();
solve( f4Eqn /*== AaL*fGlim*/);
else
fvm::ddt(rho, f4)
+ fvm::Sp(AaL,f4)
//+ fvm::Sp(AdL,f4)
f4Eqn.relax();
solve( f4Eqn == AaL*fGlim);
//Update of All Phases Coeffcients
//rho == scalar(1)/((f1+f4)/rho1 + f2/rho2 + f3/rho3);
//rhoPhi == rho*phi;
Here the declarations for pEq and p
Info<< "Reading thermodynamicProperties\n" << endl;
IOdictionary thermodynamicProperties
IOobject
"thermodynamicProperties",
runTime.constant(),
mesh,
IOobject::MUST_READ,
IOobject::NO_WRITE
dimensionedScalar pEq(thermodynamicProperties.lookup("pEq"));
Info<< "Reading field p\n" << endl;
volScalarField p
IOobject
"p",
runTime.timeName(),
mesh,
IOobject::AUTO_WRITE
mesh
The compiling error is:
Making dependency list for source file ifasFCMfoam.C
Making dependency list for source file incompressibleFourPhaseMixture/fourPhaseMixture.C
SOURCE=ifasFCMfoam.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/opt/OpenFOAM/OpenFOAM-2.1.x/src/turbulenceModels/incompressible/turbulenceModel -I/opt/OpenFOAM/OpenFOAM-2.1.x/src/transportModels -I/opt/OpenFOAM/OpenFOAM-2.1.x/src/transportModels/incompressible/singlePhaseTransportModel -I/opt/OpenFOAM/OpenFOAM-2.1.x/src/finiteVolume/lnInclude -I/opt/OpenFOAM/OpenFOAM-2.1.x/src/meshTools/lnInclude -IlnInclude -I. -I/opt/OpenFOAM/OpenFOAM-2.1.x/src/OpenFOAM/lnInclude -I/opt/OpenFOAM/OpenFOAM-2.1.x/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/ifasFCMfoam.o
In file included from ifasFCMfoam.C:76:0:
f4Eqn.H: In function ‘int main(int, char**)’:
f4Eqn.H:6:11: error: no match for ‘operator>’ in ‘pEq > p’
f4Eqn.H:6:11: note: candidates are:
In file included from /opt/OpenFOAM/OpenFOAM-2.1.x/src/OpenFOAM/lnInclude/VectorSpace.H:164:0,
from /opt/OpenFOAM/OpenFOAM-2.1.x/src/OpenFOAM/lnInclude/dimensionedType.H:41,
from /opt/OpenFOAM/OpenFOAM-2.1.x/src/OpenFOAM/lnInclude/dimensionedScalar.H:38,
from /opt/OpenFOAM/OpenFOAM-2.1.x/src/OpenFOAM/lnInclude/TimeState.H:38,
from /opt/OpenFOAM/OpenFOAM-2.1.x/src/OpenFOAM/lnInclude/Time.H:47,
from /opt/OpenFOAM/OpenFOAM-2.1.x/src/finiteVolume/lnInclude/fvCFD.H:6,
from ifasFCMfoam.C:36:
/opt/OpenFOAM/OpenFOAM-2.1.x/src/OpenFOAM/lnInclude/VectorSpaceI.H:650:13: note: template<class Form, class Cmpt, int nCmpt> bool Foam::operator>(const Foam::VectorSpace<Form, Cmpt, nCmpt>&, const Foam::VectorSpace<Form, Cmpt, nCmpt>&)
/opt/OpenFOAM/OpenFOAM-2.1.x/src/OpenFOAM/lnInclude/VectorSpaceI.H:650:13: note: template argument deduction/substitution failed:
f4Eqn.H:6:11: note: ‘Foam::dimensionedScalar {aka Foam::dimensioned<double>}’ is not derived from ‘const Foam::VectorSpace<Form, Cmpt, nCmpt>’
In file included from /opt/OpenFOAM/OpenFOAM-2.1.x/src/OpenFOAM/lnInclude/dimensionedType.H:298:0,
/opt/OpenFOAM/OpenFOAM-2.1.x/src/OpenFOAM/lnInclude/dimensionedType.C:450:6: note: template<class Type> bool Foam::operator>(const Foam::dimensioned<Type>&, const Foam::dimensioned<Type>&)
/opt/OpenFOAM/OpenFOAM-2.1.x/src/OpenFOAM/lnInclude/dimensionedType.C:450:6: note: template argument deduction/substitution failed:
f4Eqn.H:6:11: note: ‘Foam::volScalarField {aka Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>}’ is not derived from ‘const Foam::dimensioned<Type>’
In file included from ifasFCMfoam.C:49:0:
createFields.H:106:30: warning: unused variable ‘rho4’ [-Wunused-variable]
make: *** [Make/linux64GccDPOpt/ifasFCMfoam.o] Fehler 1
