-   OpenFOAM (http://www.cfd-online.com/Forums/openfoam/)
-   -   Problem implementing runTime Selection (http://www.cfd-online.com/Forums/openfoam/94010-problem-implementing-runtime-selection.html)
adhiraj November 2, 2011 22:48
Hi all,
I am trying to implement a model using runTimeSelection as per this link http://openfoamwiki.net/index.php/Op...tion_mechanism, especially section using section 4.3 as a guide.
But the subsection http://openfoamwiki.net/index.php/Op...es_to_registercauses a compilation error:
no matching function for call to ‘Foam::basicIgnitionModel::basicIgnitionModel(Foam::NoIgnition*)’
Here basicIgnitionModel is my base class, and NoIgnition is one of the derived ones.
Is there an implementation in OpenFOAM source that I can look at?
kathrin_kissling November 3, 2011 10:52
Hi!
Can you post the code line which is causing the error?
Best
Kathrin
marupio November 3, 2011 12:15
Hi Adhiraj,
The actual implementation of runTimeSelection (RTS) is hidden in OpenFOAM using a series of macros, such as addToRunTimeSelectionTable and defineRunTimeSelectionTable. So you never actually see it. This page of the wiki pulls out these sections and reconstructs them for all to see.
Section 4.3 of the wiki was not intended to be directly implemented in your code. It's just supposed to show you what's going on. But I have managed to get RTS working this way - so it is possible. What I suggest is you try using the macros. The basic ones outlined in the first few sections of the wiki page should work. If your base class or derived classes are templates, then things get more challenging.
Examples are everywhere in OpenFOAM.
Straightforward to follow:
Base: src/turbulenceModels/incompressible/RAS/RASModel
Derived: src/turbulenceModels/incompressible/RAS/kEpsilon,
Derived: src/turbulenceModels/incompressible/RAS/kOmega
Buried deep in other macros - hard to figure out:
Base: src/thermophysicalModels/chemistryModel/chemistrySolver/chemistrySolver
Derived: src/thermophysicalModels/chemistryModel/chemistrySolver/EulerImplicit
Derived: src/thermophysicalModels/chemistryModel/chemistrySolver/ode
Hope this helps!
adhiraj November 4, 2011 13:05
Thanks to both of you
Yes, and thanks for the guide. The Wiki guide was enough for my earlier work.
I tried using that part because I wanted to use templated bases and derived objects. I changed my mind and figured out a different way. So once again the first few sections should suffice.
Yes, I agree. These are indeed the functions/files I looked at before implementing the runtime selection for my earlier model.
