-   OpenFOAM (http://www.cfd-online.com/Forums/openfoam/)
-   -   findMax not working in parallel with scalarField (http://www.cfd-online.com/Forums/openfoam/94035-findmax-not-working-parallel-scalarfield.html)
pablodecastillo November 3, 2011 11:47
hello,
I found that findMax not working in parallel with scalarField.
I want to find the min coordinate_X for my pacht and at the same time with coordinate_Z <= 0.
Any idea?
Thanks
Phicau November 3, 2011 12:17
I've never tried to use findMax, but this should work:
scalar whatever = findMax...;
reduce(whatever, maxOp<scalar>());
There are other options depending on your needs: minOp, sumOp...
Regards
pablodecastillo November 3, 2011 12:25
So it would be;
label whatever = findMax...;
reduce(whatever, maxOp<label>());
I am using gMax, so get the max value, but now how can i get what label is the max value (and working in parallel)
Thanks
Phicau November 3, 2011 12:50
Just loop the entire patch:
    vectorField coord = patch().Cf();
    scalar auxiliar = 999999.0;
    forAll(coord.component(2), index)
        if(coord.component(2)[index]<=0.0)
            if(coord.component(0)[index]<auxiliar)
                auxiliar = coord.component(0)[index];
reduce(auxiliar, minOp<scalar>());
pablodecastillo November 3, 2011 13:38
thank you, but still i can not get the label for the value, any idea?
Pablo
Phicau November 3, 2011 13:55
Another loop...
    label auxiliarLabel = -999999;
    forAll(coord.component(2), index2)
            if(coord.component(2)[index2]<=0.0)
                      if(coord.component(0)[index2]==auxiliar)
                              auxiliarLabel = index2;
                              break;
reduce(auxiliarLabel, maxOp<label>());
pablodecastillo November 3, 2011 14:28
the second loop to find the cell is not working; i mean it is not giving the correct label
label celdabuscada = -99999;
scalar pto_X = -10000.0;
forAll(mesh.boundary()[patchK], faceI)
if (NN2[faceI].component(vector::Z) <= 0.0) {
if (NN2[faceI].component(vector::X) >= pto_X){
pto_X=NN2[faceI].component(vector::X);
reduce(pto_X, maxOp<scalar>());
forAll(mesh.boundary()[patchK], face2)
if (NN2[face2].component(vector::Z) <= 0.0) {
if (NN2[face2].component(vector::X)==pto_X){
celdabuscada=face2;
Info <<"////celda buscada " << celdabuscada << nl;
break;
reduce(celdabuscada, maxOp<label>());
more ideas??
