Compressible flow
Old   November 9, 2011, 08:58
Default Compressible flow
eric weddle is on a distinguished road
Hello there.
Well, I'm new with OpenFOAM and for the past month I've been using it to perform some simulations.
To do so, I took icoFoam and added a second phase to the simulation obtaining a velocity field for each phase. Later on I also added temperature transport for both phases.
Until now I've been simulating only incompressible fluids, but now I need to do the same with compressible ones.
Until now the fluids I was using had constant densities, given by a scalar value, but now I want to change this so I can assign them a variable value given by an equation, such as:
"Pressure/(R*Temperature)", being R the gas universal constant.
As you can see the density would then depend on the pressure, characterizing a compressible flow.
What modifications should I perform in my modified icoFoam so it would be able to correctly simulate this situation???
Or would it be better to use another built-in solver?
Thanks a lot
eric weddle is offline   Reply With Quote
Old   November 10, 2011, 04:41
Disabled
anon_a is on a distinguished road
Why don't you try rhoCentralFoam or another compressible solver?
I am not an expert in this field but it sounds like you will need many modifications
anon_a is offline   Reply With Quote
Old   November 10, 2011, 08:12
Vesselin Krastev
vkrastev is on a distinguished road
Use rhoPimpleFoam or rhoPisoFoam and run them in laminar mode (if you need a laminar solution)
V.
vkrastev is offline   Reply With Quote
Compressible flow, no data at the outlet mireis FLUENT 6 September 3, 2015 02:10
Natural Convection using Compressible Flow (chtMultiRegionFOAM) msarkar OpenFOAM 2 September 7, 2010 00:13
help with compressible flow BC's (need subsonic flow) meangreen Main CFD Forum 5 July 24, 2010 13:16
Compressible Fluid Flow in COMSOL Multiphysics BBG COMSOL 1 November 19, 2008 14:05
Solving unsteady compressible low speed flow atit Main CFD Forum 8 July 31, 2000 13:19
