[Sponsors] | |||||
jack
Rep Power: 3 ![]() |
hi everyone
I need to set an initial field.but when i run the funkysetFields, i met the problem: Create mesh for time = 0 Time = 0 Using funkySetFieldsDict Part: a1 Putting "0" into field alpha1 at t = "0" if condition "sqrt(sqr(pos().x-4*(10,-2))+sqr(pos().y-16*(10,-3))+(sqr(pos().z-5*(10,-3))) <= 0.005" is true --> FOAM FATAL ERROR: Parser Error at "1.23" :"syntax error, unexpected ','" "sqrt(sqr(pos().x-4*(10,-2))+sqr(pos().y-16*(10,-3))+(sqr(pos().z-5*(10,-3))) <= 0.005" " ^ " From function parsingValue in file lnInclude/CommonValueExpressionDriverI.H at line 718. I don't kown how to deal with it? Thank you for your help Best regards. lg88 |
jack
This is my funkySetFieldsDict.
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.0.1 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object funkySetFieldsDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // expressions ( a1 { field alpha1; expression_r "0"; condition "sqrt(sqr(pos().x-4*(10,-2))+sqr(pos().y-16*(10,-3))+(sqr(pos().z-5*(10,-3))) <= 0.005"; } a2 { field alpha1; expression_r "1"; condition "sqrt(sqr(pos().x-2*(10,-2))+sqr(pos().y-16*(10,-3))+(sqr(pos().z-5*(10,-3))) > 0.005"; } ); // ************************************************** *********************** // now when i input the command :funkySetFieldsDict -time 0 ,the problem is different with the former one.The new one is : --> FOAM FATAL IO ERROR: keyword expression is undefined in dictionary "::a1" file: ::a1 from line 22 to line 24. From function dictionary::lookupEntry(const word&, bool, bool) const in file db/dictionary/dictionary.C at line 400. FOAM exiting what is the problem? Can you help me ? Thank you very much Best regards lg88 |
#3 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 30 ![]() ![]() |
#4 | |
Assistant Moderator
Bernhard Gschaider
Anant Diwakar
Rep Power: 2 ![]() |
Hi
I am using funkySetFields for initializing a exponential pressure distribution. But when I am running the command "funkySetFields -time 0", the domain is getting initialized correctly but the boundary conditions in the 0/p file is getting changed on its own. Can anyone tell why is this happening ? Thanks Anant |
#6 | |
Assistant Moderator
Bernhard Gschaider
![]() Probably you didn't set "keepPatches" http://openfoamwiki.net/index.php/Co...ctionary_usage
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request |
| Tags |
| funkysetfields |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| UDF compiling problem | Wouter | Fluent UDF and Scheme Programming | 6 | June 6, 2012 04:43 |
| Gambit - meshing over airfoil wrapping (?) problem | JFDC | FLUENT | 1 | July 11, 2011 05:59 |
| natural convection problem for a CHT problem | Se-Hee | CFX | 2 | June 10, 2007 06:29 |
| Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 19:13 |
| Is this problem well posed? | Thomas P. Abraham | Main CFD Forum | 5 | September 8, 1999 14:52 |
