Compile problem on 1.6-ext
Hello Foamers,
I come across this problem when I try to compile OF 1.6-ext a version which is released from the day 7.11.2011. I took the whole source code using git and made a clean compilation using system gcc 4.4.5-6. I note that triSurface is not compiling and then many other libraries do not compile either. The solution to this problem is to remove the lines LIB_LIBS = \ -lmeshTools from file: triSurface/make/options Are there other reasons or solutions? BR/Pekka |
Can you enter "git log" and post the commit id from the top line?
Ah! Never mind, I see now where the lines were added. Can you attach the error messages that were generated when the compilation failed?
Unfortunately I deleted old logs. But now it is no longer a problem. It seems that it has already changed to source code.
BR/Pekka |
