Home > Forums > OpenFOAM
ShockTube, error message.
Old   November 16, 2011, 12:04
Default ShockTube, error message.
Alexander
foamer is on a distinguished road
Hi
i am investigating a case by using the shockTube tutorial, (rhoCentralFoam solver).
My problem is that i get an error message when i am running the simulation. the simulation starts to run, but after a short time i receive an error message. the problem is that i do not know what it means.
An excerpt of the two last iterations and the error message i receive is:
diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0
diagonal: Solving for rhoUx, Initial residual = 0, Final residual = 0, No Iterations 0
diagonal: Solving for rhoE, Initial residual = 0, Final residual = 0, No Iterations 0
ExecutionTime = 0.12 s ClockTime = 1 s
Mean and max Courant Numbers = 0.0993913 0.2
deltaT = 1e-05
Time = 0.0001
ExecutionTime = 0.13 s ClockTime = 1 s
#0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam171/lib/linux64GccDPOpt/libOpenFOAM.so"
#1 Foam::sigFpe::sigFpeHandler(int) in "/opt/openfoam171/lib/linux64GccDPOpt/libOpenFOAM.so"
#2 in "/lib/libc.so.6"
#3 Foam::sqrt(Foam::Field<double>&, Foam::UList<double> const&) in "/opt/openfoam171/lib/linux64GccDPOpt/libOpenFOAM.so"
in "/opt/openfoam171/applications/bin/linux64GccDPOpt/rhoCentralFoam"
#6 __libc_start_main in "/lib/libc.so.6"
Floating point exception
I have a fealing that the errouniosity is based on the changes i did to the setFieldsDict file. My setFieldsDict file looks like:
defaultFieldValues ( volVectorFieldValue U ( -1000 0 0 ) volScalarFieldValue T 349 volScalarFieldValue p 100000 );
regions ( boxToCell { box ( 0 -1 -1 ) ( 5 1 1 ) ; fieldValues (volVectorFieldValue U ( 1000 0 0 ) volScalarFieldValue T 349 volScalarFieldValue p 100000 ) ; } );
i will have deeply appreciated if someone could have explained to me what the error message means and what i can do to cope with this problem.
Alex
foamer is offline   Reply With Quote
Old   November 17, 2011, 06:37
Alexander
Hi
I think i know what is the problem.
When i check the pressure in time folder 0.001 i eventually get negative pressure. So i guess this has to do with the numerics in the algorithm or so, that it cannot handle it.
Alex
Old   December 1, 2012, 03:13
Default zero residuals
Farshad
Farshad_Noravesh is on a distinguished road
Did you solve the problem? I am still getting your error. Even when i use other tutorials of rhoCentralFoam i still get the same error.
please help me.
Kind Regards,
Farshad
Farshad_Noravesh is offline   Reply With Quote
Old   December 1, 2012, 16:22
Alexander
Originally Posted by Farshad_Noravesh View Post
please help me.
Kind Regards,
Farshad
Farshad, i think the velocity is too high...if you lower the velocity to 900 m/s it should be able to run...
Hope this will work for you
alex
Old   December 2, 2012, 18:02
immortality's Avatar
Ehsan
immortality is on a distinguished road
may be the problem is from turbulency
immortality is offline   Reply With Quote
Old   December 3, 2012, 08:37
Alexander
Ok, could you please specify that a little more ?
alex
Old   December 4, 2012, 13:24
Ehsan
I have the same problem.it seems the equations of rho don't solve at all.because rho,rhoUx,rhoUy,rhoUz and rhoe are zero in my run.
I don't whats the cause of the problem.
Old   December 10, 2012, 12:44
praveen's Avatar
Praveen. C
praveen is on a distinguished road
Try reducing cfl number and/or time step.
praveen is offline   Reply With Quote
Old   January 30, 2013, 05:31
Valentin Wibaut
vwibaut is on a distinguished road
Hi all,
I'm solving the flow in a nozzle and I have the same problem that foamer
Just reducing the velocity solves your problem?
Regards
vwibaut is offline   Reply With Quote
Thread Tools
Trackbacks are On
Shocktube in OpenFoam foamer OpenFOAM 6 January 5, 2013 11:02
Shocktube help needed please cfdguy08 FLUENT 4 October 4, 2010 07:31
shockTube simulation different solvers feijooos OpenFOAM Running, Solving & CFD 8 November 20, 2009 18:20
SHOCKTUBE INITIAL CONDITION Stefano FLUENT 0 May 10, 2006 15:55
help:gas-water shocktube problem gooo Main CFD Forum 0 May 8, 2005 22:51
