-   OpenFOAM (http://www.cfd-online.com/Forums/openfoam/)
-   -   LES in twoPhaseEulerFoam (http://www.cfd-online.com/Forums/openfoam/94502-les-twophaseeulerfoam.html)
hkhosravi November 17, 2011 13:08
dear foamer
if i have correct understanding, twoPhaseEulerFoam can use LES turbulence model ? is it true?
if yes, how can i use it in simulation of fluidized bed?
regards,
cheng1988sjtu November 23, 2011 00:19
LES need to included
I think the default turbulence model is kEpsilon model.
if you need to use LES in twoPhaseEulerFoam, then you may need to modify the code a little bit.
Zhen
Originally Posted by hkhosravi (Post 332545)
dear foamer
regards,
hkhosravi November 23, 2011 01:53
thanks Charlie
what is the meaning of the filterProperties file in its case??
cheng1988sjtu November 23, 2011 15:24
filterProperties
According to a tutorial, the function is set the flux to be 0 at the filter position and specified plane.
Zhen
Originally Posted by hkhosravi (Post 333209)
thanks Charlie
grjmell February 17, 2012 12:17
I don't think it does anything... i cant find any reference to filter in the code at all...?
ehsan February 26, 2012 06:21
Could I kindly ask you which filter type is used in LES of incompressible flows OpenFoam? In fact, we don't set any filter in LESproprties.
Regards
