Home > Forums > OpenFOAM
boundary condition
Old   November 23, 2011, 05:48
Default boundary condition
lynda
lyna is on a distinguished road
hello,
I have a configuration composed of two coaxial cylinders, the length of inner cylinder is inferior to that of the outer cylinder. so it's a 2D axisymmetric problem.
my problem lies in the boundary conditions of the inner cylinder, precisely in the cylinder walls inside. These are my bets:
patches
wall fixedWall
(3 4 10 9) // internal cylinder walls (length L1)
(6 7 13 12) //outer cylinder wall (length L1)
(7 8 14 13) //outer cylinder wall (length L2)
BlockMesh gives me the following error message :
>> Trying to specify a boundary face 4(3 4 10 9) on the face on cell 0 which is either an internal face or already belongs to some other patch. This is face 0 of patch 0 named fixedWall.
how to fix this error please?????
lyna is offline   Reply With Quote
Old   November 23, 2011, 06:34
Bernhard
Bernhard is on a distinguished road
The error message is quite clear. The first face in your list (3 4 10 9) is already in some other patch. Or it is not a boundary patch but internal.
Did you check your geometry with Paraview for example, to check this?
Bernhard is offline   Reply With Quote
Old   June 12, 2012, 12:45
Default parallel run
lynda
hello,
to save time, I want to start my calculations in parallel, but I did not understand the method explained in the manual.
can you send me an example that was already done, explaining the whole procedure.
thanks
Thread Tools
Trackbacks are On
Boundary Conditions Thomas P. Abraham Main CFD Forum 20 July 7, 2013 05:05
Setting outlet Pressure boundary condition using CAFFA code Mukund Pondkule Main CFD Forum 0 March 16, 2011 04:23
Domain Imbalance HMR CFX 3 March 6, 2011 21:10
How exactly the "pressure outlet" bdry condition compute properties on the boundary? yating9901 FLUENT 3 June 28, 2010 12:26
How to set boundary condition in Fluent for the fo Peiyong FLUENT 1 November 10, 2006 12:44
