-   OpenFOAM (http://www.cfd-online.com/Forums/openfoam/)
-   -   simple question about boundaryT (http://www.cfd-online.com/Forums/openfoam/94831-simple-question-about-boundaryt.html)
spk November 27, 2011 19:25
Hi guys,
I run a 2D orifice geometry using dsmcFoam!
The temperature inside the orifice geometry is 293 K and remains constant.
The types of the boundary conditions are: wedge,
wall, total pressure, pressureInletVelocity and "empty" for
frontAndBackPlanes.
In the "0" folder there is a boundaryT file, as i can see in the
dsmc tutorials.
I have to define the temperature for all the types of boundary conditions?
And for the value, i will define uniform and 293 K?
Thanks!!!
anon_a November 28, 2011 04:14
The temperature is needed for boundaries where particles are being injected with a Maxwellian distribution. Therefore, you would not need this for empty, symmetryPlane and wedge boundaries (note that wedge does not work with dsmcFoam).
The temperature value depends on the definition of your problem. I assume that the temperature of the gas in the containers upstream and downstream is 293K and therefore yes, you need to use "uniform 293".
spk November 28, 2011 05:00
Thanks a lot anon_a!
I'll use symmetryPlane instead of wedge!
Yes the temperature of the gas in the containers upstream and downstream is 293K, ok i'll use uniform 293!
spk November 28, 2011 05:09
For the wall of the orifice, i'll define uniform 293?
The only thing i know is that the temperature of the gas in the containers upstream and downstream is 293K.
anon_a November 28, 2011 08:09
Again, it depends on the definition of your problem.
There is no readily available boundary condition for adiabatic walls in dsmcFoam and you don't specify another temperature for the walls so I guess I would use isothermal walls at 293K. That is the usual case.
spk November 28, 2011 18:56
Thanks anon_a!!!
