multiple cyclic fans and outlets irregular ( checkerboard ) pressure on patch faces
Old   November 30, 2011, 08:05
Default multiple cyclic fans and outlets irregular ( checkerboard ) pressure on patch faces
Andy Lowe
ajl42 is on a distinguished road
Hi Everyone,
I've built a simpleFoam test problem with an inlet, an outlet and two cyclic fans. The simpleFoam solver runs and the residuals fall nicely. The results appear sensible unitl I look at the fan cyclic patches. Here I find an irregular pressure distribution which is more like pressure checker boarding. The velocity field shows similar irregular velocities. I've noticed similar pressure fields at outlets also but these aren't as noticeable. Am I asking too much of the sinmpleFoam solver set up, I'm new to this set up.
Has anyone else found this? Help!
Many thanks,
Andy.
I've added some pictures of my problem.
Last edited by ajl42; December 1, 2011 at 14:27. Reason: More info on the problem.
ajl42 is offline   Reply With Quote
checkerboard, cyclic, fan, pressure, simplefoam
