-   OpenFOAM (http://www.cfd-online.com/Forums/openfoam/)
-   -   mesh convertion from starCD grid to OpenFOAM (http://www.cfd-online.com/Forums/openfoam/94894-mesh-convertion-starcd-grid-openfoam.html)
ahmed_khatibs November 29, 2011 08:35
how to convert starCD grid (.vrt, .bnd, .cel) to Openfoam and/or fluent grid,which file should be taken for conversion from three files?
wyldckat November 29, 2011 17:43
Greetings Ahmed,
According to the help given by star4ToFoam:
$ star4ToFoam -help
Usage: star4ToFoam [OPTIONS] <pro-STAR prefix>
options:
-ascii write in ASCII instead of binary format
-case <dir> specify alternate case directory, default is the cwd
-noFunctionObjects
do not execute functionObjects
-scale <factor> geometry scaling factor - default is 0.001 ([mm] to [m])
-solids retain solid cells and treat them like fluid cells
-srcDoc display source code in browser
-doc display application documentation in browser
-help print the usage
convert pro-STAR (v4) mesh to OpenFOAM
Using: OpenFOAM-2.0.x (see www.OpenFOAM.org)
So basically you need the 3 files, but only need to tell star4ToFoam the name of the file (without the extension nor the dot).
Best regards,
Bruno
ahmed_khatibs December 27, 2011 02:07
thank u...
