[swak4Foam] evaporation / vapor flux / groovyBC |
December 4, 2011, 23:17 |
shinya ogata
Hi!
I want to calculate water evaporation with simpleFoam. I have already added moisture field as X in simpleFoam solver. And then, I am trying to make evaporation boundary using groovyBC. I wrote a boundary condition of vapor flux referring to heat flux. z_ { type groovyBC; value uniform 0; gradientExpression "gradX"; fractionExpression "0"; variables "alphac=5.8+3.9*mag(internalField(U));Xs=0.0167;al fadash=3.6*alphac/3600;capadash=1;rhodash=1.2;gradX=alfadash*(Xs-internalField(X))/(kappaEffX*capadash*rhodash);"; } SimpleFoam has done without any error. But amount of water evaporation is too little comparing to a experiment data. Is the boundary condition which I wrote right ? Shinya |
December 5, 2011, 05:57 |
#2 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
a) never trust experimental data b) if you use internalField like that I'd expect some kind of grid dependence. Try changing the resolution and see if that makes a difference |
December 11, 2011, 01:53 |
shinya ogata
Hi gschaider !
Thank you for your advise! I subdivided mesh and the amount of evaporation changed. As you pointed, it could be mesh dependence. I will try to find appropriate mesh. Thank you again. Shinya |
December 11, 2011, 07:14 |
#4 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
http://openfoamwiki.net/index.php/Co...g_to_need_are: Good luck |
December 13, 2011, 04:43 |
shinya ogata
Hi gschaider !
Your advise is right. Even if I found appropriate mesh comparing with experiment, I cannot use it with another model. I will try to make mesh-independent formulation. Thank you again. Shinya |
evaporation groovybc |
Water Surface Evaporation | sunggun1212 | FLUENT | 3 | January 11, 2020 05:12 |
[swak4Foam] groovyBC for oscillatory flow | liybzd | OpenFOAM Community Contributions | 5 | November 12, 2018 08:53 |
[swak4Foam] reactingMultiPhaseEulerFoam problems with groovyBC | zanilu70 | OpenFOAM Community Contributions | 4 | December 13, 2016 07:46 |
[swak4Foam] Change in alpha and U with groovyBC in twoPhaseEulerFoam | dani2702 | OpenFOAM Community Contributions | 0 | November 17, 2016 04:30 |
Liquid Evaporation Model Error in OF 2.3.0 | brbbhatti | OpenFOAM | 11 | June 16, 2014 10:40 |
