-   OpenFOAM (http://www.cfd-online.com/Forums/openfoam/)
-   -   zeroGradient BC for velocity at oulet (http://www.cfd-online.com/Forums/openfoam/95151-zerogradient-bc-velocity-oulet.html)
achinta December 7, 2011 14:24
Hi all,
I am implementing my own solver in OF. I have 1D flow case. The velocity boundary condition at the outlet is zeroGradient. But, the results obtained are contradicting the BCs. Seems, OF is not implementing the BC. Here are the velocity values at time t=0.1s
(4.91905 0 0)
(4.91905 0 0)
(4.91905 0 0)
(4.91905 0 0)
(4.91905 0 0)
(4.91905 0 0)
(4.9188 0 0)
(4.94397 0 0)
(4.64658 0 0)
(6.06569 0 0)
(2.02726 0 0)-----OUTLET
boundaryField
inlet
type timeVaryingUniformFixedValue;
fileName "velocity";
outOfBounds clamp;
value uniform (1.00004 0 0);
outlet
type zeroGradient;
fixedWalls
type empty;
frontAndBack
type empty;
Could anyone please tell me where I went wrong?
Thanks,
AV
achinta December 8, 2011 12:37
Hello everyone,
I would like to add some more information. I am using PISO algorithm. The following boundary conditions were given to the unsteady, compressible 1 D pipe/channel flow:
For VELOCITY
inlet
outOfBounds clamp;
outlet
type zeroGradient;
fixedWalls
type empty;
frontAndBack
type empty;
For PRESSURE:
inlet
type zeroGradient;
outlet
type fixedValue;
value uniform 100000;
fixedWalls
type empty;
frontAndBack
type empty;
Please comment whether the boundary conditions are specified correctly for the given case.
Regards,
AV
mturcios777 December 8, 2011 14:04
I believe your error is caused by having the fixedWalls as an empty boundary condition. When you say 1D channel flow, I am assuming you mean something like Hagen-Poiseuille flow (unsteady here as you are ramping the outlet velocity).
If fixedWalls are the walls of the pipe, then you currently have no boundary condition there. Empty is used to tell OF not to solve on that region. I would suggest you change the velocity BC to fixedValue (0 0 0) and the pressure BC to zeroGradient on those boundaries.
If I have assumed something different than what you are trying to accomplish we'll need more information to help you with (what OF solver is your new solver most like, what modifications you have made, etc).
achinta December 8, 2011 16:08
I am developing a PISO-based algorithm to solve low-mach number reacting flow. Its solves continuity, momentum and scalar transport equation. The density is related to scalar(c=1, if fuel is present, c=0:fuel absent) using an empirical equation. It is similar to 'rhoPisoFoam' without the hEqn and rhoEqn. Extra scalar transport equation is added.
I have to validate my code. I have analytical solution for unsteady,compressible reacting 1 D flow(along axial direction-x axis, not along y-axis) without pressure gradient and viscosity. This is not a pressure driven flow-pressure is constant through out the domain. The fuel burns, density decreases, velocity of fluid increases(to conserve mass) and hence the flow is driven from inlet to outlet.
Hence, to compare analytical solution, i created a rectangular pipe. To avoid the effect of viscosity, i didnt give 'no slip' conditions to fixedwalls. To make it 1D along axis, I gave 'empty' conditions to fixed walls. I gave the boundary condition mentioned in previous post.
Am I following the right procedure?
Thank you very much for your reply.
AV
mturcios777 December 8, 2011 16:39
Wow, something very different indeed. Is the inlet velocity boundary condition related to the consumption of fuel (with subsequent density decrease)?
achinta December 8, 2011 17:37
The product of density and velocity is a constant. Density depends on scalar(c). Hence, velocity boundary condition at inlet depends on scalar. But, the time varying boundary conditions for velocity and scalar(c) are given in "Scalar.dat" and "velocity.dat" files. The boundary condition for 'c' is similar to velocity BC.
Here is the BC for 'c':
inlet
fileName "Scalar";
outOfBounds clamp;
outlet
type zeroGradient;
fixedWalls
type empty;
frontAndBack
type empty;
The values in "Scalar" and "velocity" files are calculated from the analytical formula at x=0.
Should I change BC for pressure to get correct results? Which is the best way to make sure that pressure is constant throughout the domain? In the OpenFOAM results, pressure changes considerably near inlet and product of density and velocity is not constant near the inlet. please suggest some methods.
Regards,
AV
mturcios777 December 8, 2011 19:08
I'm taking that you are concerned with that sudden changes in velocity before the outlet. Its difficult for me to tell without knowing the equations you are trying to solve. I'm curious how your a PISO solver handles zero density where there is no fuel. Is this a model you have developed or is there some literature I could see to have a better idea.
achinta December 8, 2011 19:18
Density and c are related through the formula:
Density=0.6-(0.4*tanh(10*(0.5-c))); c-scalar
So, rho is not zero even when c=0. There is no zero density region. c=0 means fuel is completely burnt-doesn't mean there is no fluid.
I am solving standard unsteady,compressible continuity and momentum equations. The code also includes scalar transport equation for 'c'.
achinta December 10, 2011 04:33
5 Attachment(s)
I observe differences between analytical and OF results (please find the attached files).I had assumed zeros pressure gradient(dp/dx=0) while deriving analytical solution. In openFoam, its difficult to maintain zero pressure gradient through the domain. Are these errors due to the dp/dx=0 assumption?
The attachments are:
v1- velocity plot at time=0.1s
v5- velocity plot at time=0.5s
v10- velocity plot at time=1s
d1-density plot at time=0.1s
d5-density plot at time=0.5s
The error in velocity is high is low density region (flat region of the velocity profile)
Thanks,
AV
mturcios777 December 16, 2011 15:00
Since the shape of the velocity profile is similar to the analytical solution, I think your boundary conditions are okay. When you say unsteady flow, what part of the solution is unsteady in the analytical version? Your analytical solution appears constant in time for both density and velocity. If you leave the solver to run for longer than 1s (simulation time I assume), does the flat region of the velocity profile keep growing?
