April 26, 2011, 06:57 |
Reletive Motion
Dan
Rep Power: 15 |
Hi all,
I am working on simulating the flow over a moving three dimensional body immersed in incompressible fluid. In openFoam 1.7.0, I am using pimpleDyMFoam to achieve the local deformation of the body however I now need to simulate the net movement of the body. To minimize the mesh transformation cost and to keep my object of interest centered in my mesh, I wish to take a Eulerian approach, and simply update the relative free stream velocity at each iteration. For this I need to update not just the relative boundary velocity values but also the velocities of the internal mesh. Can anybody suggest a way to achieve this. Am I missing an obvious trick here? |
April 26, 2011, 15:17 |
Pablo
Rep Power: 17 |
Hi Dan,
I think that you can do it with solidbodymotion, it has SDA and SDK class, who let define movements for the domain. But they are very restrictives. So it seems that if you want to implement your own movements with ODE or similar, you can move your domain with fvMesh::movePoints. fvMesh::movePoints will move your points and calculate volumen variation, phi variation etc... then this value will be used by makerelative or makeabsolute to take account the influence of the velocity body/domain in your problem. In theory it will be done, if it is wrong i hope that somebody give light. Do not forget say mesh.moving(true);, or makerelative and absolute is not going to work. Pablo |
April 26, 2011, 16:11 |
Sandeep Menon
Rep Power: 25 |
fvMesh::movePoints() calls polyMesh::movePoints(), which in-turn calls the moving(bool) member function, so there's no need to call the moving() function explicitly
April 26, 2011, 17:38 |
Pablo
Rep Power: 17 |
And when/where is updated C() and Cf()?, i was trying to find it without succesful.
Pablo |
April 26, 2011, 19:55 |
Sandeep Menon
Rep Power: 25 |
All geometry is demand-driven. Once movePoints is called, geometry information is cleared (using clearGeom()? Can't remember the function name), and reconstructed on-demand only when mesh.C(), etc is called the next time.
Look for calls to deleteDemandDrivenData() in the source-tree for clues... |
April 26, 2011, 22:24 |
Pablo
Rep Power: 17 |
So, i can not find what i am missing.
I am coding a solver based in interdymfoam, but using my own movement mesh. The problem is that when i move all the domain, the free surface is moving with the domain, it is like flux relative was not working right for phi interface. Any idea? Pablo |
April 27, 2011, 12:29 |
Pablo
Rep Power: 17 |
I go to try to explain my problem better;
The solver is solving the towing tank resistance for ships with trim and sink. It is using rigid body motion (motion for all the domain) to trim&sink. The mistake is coming when solving the sink, when the boat (all the domain) goes up or down, the free surface is going with him (so if the body sink 10 cm all the domain is moving too 10 cm and the free surface level too). It means that the relative flux is not updating the free surface or i am not giving the properly boundary conditions. Any idea?? Advanced thanks |
April 27, 2011, 19:19 |
Pablo
Rep Power: 17 |
Hello again,
I found that i have no relative flux, i did it surfaceScalarField phi44 = fvc::meshPhi(U); and i got 0 for the average of phi44. It seems that phiPtr_ is not saving the old value. Anybody can help me to figurate what is happening? Pablo |
December 6, 2011, 12:08 |
#9 |
Arne Stahlmann
Rep Power: 17 |
Hi Pablo,
I think I am facing a similar problem right now (but am still figuring out if it might be related to your situation): After modifying the point positions, the water in my flume is running out of it. Boundary conditions for U and alpha1 are still properly defined. So: Did you figure out what the reason was, and could you fix it? Greetings, Arne |
December 20, 2011, 07:08 |
#10 |
Pablo
Rep Power: 17 |
Hi Arne,
Sorry this late reply. I fixed doing fix the velocity at the top and bottom of the domain, in my case it works pretty well. Pablo |
Mesh motion on inlet (2-way FSI) | Lance | CFX | 2 | August 13, 2009 05:31 |
Convergence moving mesh | lr103476 | OpenFOAM Running, Solving & CFD | 30 | November 19, 2007 14:09 |
tank motion on boat | Tim | FLUENT | 0 | May 23, 2007 11:50 |
large scale mesh motion | sb | FLUENT | 1 | April 27, 2007 22:23 |
Can I define grids motion as a time functions | Darcy | CFX | 4 | March 29, 2001 21:14 |
