vertice ordering?
I am trying to write the blockmeshDict file. can somebody please say how should i order my vertices? 1) where should my origin be in the block ? with the origin, I can figure out the direction using the right handed coordinate system but where to put my origin? I have seen the user guide but no help in this.. Pl help. am getting tonnes of wrong oriented faces in checkMesh.. |
The ordering of your points is not important. The ordering in the face and the hexes is. The face should be oriented such, the normal (defined via right-hand-rule) is pointing outward. In other wards: If you look from the inside out, you should order the point in a clockwise manner.
The numbering of the hexes is given in Fig 5.5: http://www.openfoam.org/docs/user/blockMesh.php Have fun :) |
Thanks for the reply.
Sorry i didn't put my question correctly. I try again: 1)in each hex block, i should start numbering from on vertex. How should i chose which vertex to start from? Once i know the starting vertex, I can start from there and move along the edges as shown in the user guide. 2) how should i orient the local co ordinate axis at the starting vertex? i can figure out that first i have to go along x(x1) , then in the direction of y(x2), finally in the direction of z(x3). After this i go along x and y in the new plane that is offset from the old one. But in which direction should i orient the local x axis in the first place? Pl help.:( |
origin of hex block
3 Attachment(s)
Hi ,
I am am still having the same problem. I am trying to mesh the space between 2 concentric cylinders and i couldn't figure out where to put the origin of each hex block. I am ok with numbering scheme of faces, to have the normal pointing out. In my attempts, I get a good mesh until 3 quadrants, shown in pic2. But when i join the fourth and final hex block to the third and first, I get blockmesh error: --> FOAM FATAL IO ERROR: ill defined primitiveEntry starting at keyword 'blocks' on line 40 and ending at line 115 file: /home/balaji/OpenFOAM/balaji-2.0.1/run/cc7/constant/polyMesh/blockMeshDict at line 115. From function primitiveEntry::readEntry(const dictionary&, Istream&) in file db/dictionary/primitiveEntry/primitiveEntryIO.C at line 165. FOAM exiting I have put the order of my origins in each block in pic 1 ( it is z=0 plane). I have also posted my blockMeshDict. Some body pl help.. |
Make sure to read over your blockMesh file very carefully. Your blocks are defined just fine. You are missing a space on your last hex definition, between simpleGrading and the left parenthesis.
For future reference, when OF gives you an ill defined primitiveEntry error (in any input file), that means there is something wrong with the syntax, and you've likely missed a space/comma/colon/semicolon etc. |
Thanks a lot.....
1 Attachment(s)
Thanks a thousand^thousand ton .
I got the mesh finally to look right. I didn't know blockMesh was so picky. Thanks a lot mturcios777. Have put a pic of my mesh below. |
Hi Bernhard,
The user guide says: Quote:
Best Regards, Toni |
What you mention comes in only at the point where you define your blocks. This has to be consistent with the order in the vertices subdict. If you change the ordering in vertices, you have to change the numbers in your block and patch definitions.
Hi Bernard,
thanks for your fast reply. If I understand you right, it doesn't matter how I order my vertices as long as the new order matches the correct block definition. My model consists of many blocks. I went back to just 2 blocks to see what I'm doing wrong: Code:
convertToMeters 0.001; Code:
--> FOAM Warning : |
Please make a sketch of your situation and follow the order in the as in the manual. You're now defining them the wrong way around:
hex( 0 1 7 6 3 4 10 9) Code:
hex (0 3 4 1 6 9 10 7) |
Finally...
I tried your first suggestion. (I couldn't see how the second suggestion differs from my first try.) It works, thank you! Because of your help and the user guide i got it working. |
ill defined primitiveEntry starting at keyword 'vertices' on line 21 and ending at li
hello,
I am trying to create a cuboid mesh using blockMesh having 5 blocks, one at centre and other four blocks around the central one. but after running the blockMesh command, i am getting following error and i am not able to figure out my mistake. --> FOAM FATAL IO ERROR: "ill defined primitiveEntry starting at keyword 'vertices' on line 21 and ending at line 107" file: /home/sud/mmcRun/CH4D60/constant/polyMesh/blockMeshDict at line 107. From function primitiveEntry::readEntry(const dictionary&, Istream&) in file lnInclude/IOerror.C at line 132. FOAM exiting My blockMeshDict file is: convertToMeters 0.001; vertices ( (-22.85 -22.85 0) //0 (22.85 -22.85 0) //1 (22.85 22.85 0) //2 (-22.85 22.85 0) //3 (-91.40 -91.40 0) //4 (91.40 -91.40 0 //5 (91.40 91.40 0) //6 (-91.40 91.40 0) //7 (-22.85 -22.85 470) //8 (22.85 -22.85 470) //9 (22.85 22.85 470) //10 (-22.85 22.85 470) //11 (-91.40 -91.40 470) //12 (91.40 -91.40 470) //13 (91.40 91.40 470) //14 (-91.40 91.40 470) //15 ); blocks ( hex (0 1 2 3 8 9 10 11) (40 40 240) simpleGrading (1 1 1) //centre hex (3 2 6 7 11 10 14 15) (40 40 240) simpleGrading (1 1 1) //top hex (4 0 3 7 12 8 11 15) (40 40 240) simpleGrading (1 1 1) //left hex (5 1 0 4 13 9 8 12) (40 40 240) simpleGrading (1 1 1) //bottom hex (5 6 2 1 13 14 10 9) (40 40 240) simpleGrading (1 1 1) //right ); edges ( ); boundary ( outlet { type patch; physicalType particleOutflow; faces ( (11 10 9 8) (15 14 10 11) (15 11 8 12) (8 9 13 12) (10 14 13 9) ); } side { type patch; physicalType particleOutflow; faces ( (6 5 13 14) (7 6 14 15) (4 7 15 12) (5 4 12 13) ); } inletCoflow { type patch; physicalType noParticleOutflow; faces ( (0 1 2 3) (2 6 7 3) (3 7 4 0) (0 4 5 1) (1 5 6 2) ); } ); mergePatchPairs ( ); can someone figure out where i am making mistake? |
Can someone help me with the HEX order? I'm trying to do an elbow simulation and dont have problem defining the first two blocks, but i'm getting this error which means my third hex is not right handed and Idk why it's not!
--> FOAM FATAL IO ERROR: Block hex (9 8 12 13 11 10 14 15) (10 10 10) simpleGrading (1(1) 1(1) 1(1)) has inward-pointing faces 4(13 15 14 12) 4(9 13 12 8) 4(11 10 14 15) Code:
convertToMeters 1; |
