-   OpenFOAM (http://www.cfd-online.com/Forums/openfoam/)
-   -   Accessing particular faces (http://www.cfd-online.com/Forums/openfoam/96334-accessing-particular-faces.html)
deji January 19, 2012 17:24
Greetings to all at the OpenFOAM forum.
If I have a set of faces set aside, let's say 10 of them in my computational domain and those faces are:
label neededFaces, how can I get flow quantities of those particular faces only? I already have a surfaceScalarField of my entire domain, but I only want these 10 to use someplace else....So how can I do that Foamers?
linnemann January 19, 2012 21:29
Hi
I would use foamToVTK -faceSet and use Paraview to access the data using a programmable filter or python calculator.
Then you have access to your data only in those 10 faces, and can calculate your desired stuff.
http://www.vtk.org/Wiki/Python_Programmable_Filter
http://www.itk.org/Wiki/Python_Calculator
deji January 19, 2012 21:49
Thanks for the reply Niels. But I need those quantities for an LES wall function that I am implementing into OpenFOAM, so they are required at runtime. Any ideas? Thanks.
linnemann January 19, 2012 21:58
Hi
Well it didnt say it had to be runtime :)
I havent looked into the coding of it but just as MRFSimpleFoam operates on a faceSet/cellSet it must be possible to see how the Coriolis force is added to the faces/cells and then reusing that for your wall function.
deji January 19, 2012 22:02
Thanks much Niels, I am going to look into the code myself.
Cheers,
Deji
deji January 20, 2012 15:27
I do not think that solver is in OpenFOAM anylonger, atleast not in OpenFOAM-1.7. Do you know what version has the code?
linnemann January 23, 2012 03:43
For 1.7.x its in the tutorials/incompressible/MRFSimpleFoam/MRFSimpleFoam folder
For 2.x versions its in the regular place for solvers.
