ConjugateInterHeatFoam in OF.1.6-ext..need help to fix the error!!!
Old   February 2, 2012, 19:02
Default ConjugateInterHeatFoam in OF.1.6-ext..need help to fix the error!!!
farhagim is on a distinguished road
Hello Guys,
I modified the conjugateHeatFoam solver in OF.1.6-ext to couple my interHeatFoam solver with solid part. I managed to compiled the solver without problem. But When I am trying to run it in a case of droplet impact on hot surface, it shows me this error:
Create time
Create mesh for time = 0
// using new solver syntax:
T
solver PCG;
preconditioner DIC;
tolerance 1e-06;
relTol 0;
Reading transportProperties
Reading field pd
Reading field alpha1
Reading field U
Reading field T
Selecting incompressible transport model Newtonian
Reading / calculating rho*cp
Reading / calculating rho*phi*cp
Reading g
Calculating field g.h
--> FOAM FATAL ERROR:
LHS and RHS of + have different dimensions
dimensions : [0 2 -2 0 0 0 0] + [1 -1 -2 0 0 0 0]
From function operator+(const dimensionSet& ds1, const dimensionSet& ds2)
in file dimensionSet/dimensionSet.C at line 408.
FOAM aborting
Aborted
I think this error comes from CreateField file, So I bring it here for you guys to see if any parts of it need to be fixed.
Info<< "Reading transportProperties\n" << endl;
IOdictionary transportProperties
IOobject
"transportProperties",
runTime.constant(),
mesh,
IOobject::MUST_READ,
IOobject::NO_WRITE
Info<< "Reading field pd\n" << endl;
volScalarField pd
IOobject
"pd",
runTime.timeName(),
mesh,
IOobject::AUTO_WRITE
mesh
Info<< "Reading field alpha1\n" << endl;
volScalarField alpha1
IOobject
"alpha1",
runTime.timeName(),
mesh,
mesh
Info<< "Reading field U\n" << endl;
volVectorField U
IOobject
"U",
runTime.timeName(),
mesh,
mesh
Info << "Reading field T\n" << endl;
volScalarField T
IOobject
"T",
runTime.timeName(),
mesh,
mesh
# include "createPhi.H"
twoPhaseThermalMixture twoPhaseProperties(U, phi);
const dimensionedScalar& rho1 = twoPhaseProperties.rho1();
const dimensionedScalar& rho2 = twoPhaseProperties.rho2();
const dimensionedScalar& cp1 = twoPhaseProperties.cp1();
const dimensionedScalar& cp2 = twoPhaseProperties.cp2();
// Need to store rho for ddt(rho, U)
volScalarField rho
IOobject
"rho",
runTime.timeName(),
mesh,
IOobject::READ_IF_PRESENT
alpha1*rho1 + (scalar(1) - alpha1)*rho2,
alpha1.boundaryField().types()
rho.oldTime();
// Mass flux
// Initialisation does not matter because rhoPhi is reset after the
// alpha1 solution before it is used in the U equation.
surfaceScalarField rhoPhi
IOobject
"rho*phi",
runTime.timeName(),
mesh,
IOobject::NO_READ,
IOobject::NO_WRITE
rho1*phi
// Need to store rho*Cp for ddt(rho*Cp, T)
// Initialisation does not matter because rhoCp is reset after the
// gamma solution before it is used in the T equation.
Info<< "Reading / calculating rho*cp\n" << endl;
volScalarField rhoCp
IOobject
"rho*Cp",
runTime.timeName(),
mesh,
IOobject::NO_READ,
IOobject::NO_WRITE
alpha1*rho1*cp1 + (scalar(1) - alpha1)*rho2*cp2,
rhoCp.oldTime();
// Energy flux
// Initialisation does not matter because rhoPhiCp is reset after the
Info<< "Reading / calculating rho*phi*cp\n" << endl;
surfaceScalarField rhoPhiCp
IOobject
"rho*phi*cp",
runTime.timeName(),
mesh,
IOobject::NO_READ,
IOobject::NO_WRITE
rhoPhi*cp1
#include "readGravitationalAcceleration.H"
Info<< "Calculating field g.h\n" << endl;
volScalarField gh("gh", g & mesh.C());
surfaceScalarField ghf("ghf", g & mesh.Cf());
volScalarField p
IOobject
"p",
runTime.timeName(),
mesh,
IOobject::NO_READ,
pd + rho*gh
label pdRefCell = 0;
scalar pdRefValue = 0.0;
setRefCell(pd, mesh.solutionDict().subDict("PISO"), pdRefCell, pdRefValue);
scalar pRefValue = 0.0;
if (pd.needReference())
pRefValue = readScalar
mesh.solutionDict().subDict("PISO").lookup("pRefVa lue")
p += dimensionedScalar
"p",
p.dimensions(),
pRefValue - getRefCellValue(p, pdRefCell)
// Construct interface from alpha1 distribution
interfaceProperties interface(alpha1, U, twoPhaseProperties);
// Construct incompressible turbulence model
autoPtr<incompressible::turbulenceModel> turbulence
incompressible::turbulenceModel::New(U, phi, twoPhaseProperties)
# include "attachPatches.H"
Please help me to fix this problem.
Thanks,
Mehran
farhagim is offline   Reply With Quote
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 09:31
Accessing phi from a fvPatchField at same patch johndeas OpenFOAM 1 September 13, 2010 20:23
UDF: DEFINE_CG_MOTION for vertical jump motion of an electrode! alban Fluent UDF and Scheme Programming 2 June 8, 2010 18:54
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
user defined function cfduser CFX 0 April 29, 2006 10:58
