April 13, 2011, 07:00 |
Cyclic GGi Vs cyclic patch
Kurne
Rep Power: 15 |
Dear All
Will anybody explain what is the difference between the Cyclic GGi Vs cyclic patch.I am asking this because i have run my case with cyclic patch in OpenFOAM 1.7.1 and the same case is not running in OpenFOAM 1.5-Dev and giving error.But i resolve this problem in OpenFOAM 1.5-Dev by changing the patch conditions i.e.cyclic to fixed value. Please Help. Thanks In Advance.
Simulation Is Determination Of Imagination Towards Approximation ® Best Regards Mubeen K Kurne |
April 13, 2011, 08:35 |
#2 | |
maddalena
Rep Power: 23 |
mad |
April 15, 2011, 01:49 |
Kurne
Rep Power: 15 |
Dear maddalena
Yeah thats right maddalena cyclic required two patches and cyclicGGI is available with extension version but i want to know the difference between two. Well, if u and anyone know how to apply cyclicGGI then please let me know because i an stuck up with the cyclicGGI conditions. Lastly thanks a lot for replying.
April 15, 2011, 04:07 |
#4 | |
maddalena
Rep Power: 23 |
There is no difference on the results between the two. However:
mad |
April 15, 2011, 04:35 |
Kurne
Rep Power: 15 |
Dear maddalena
With the guidance of you only i have created the cyclic patch and will you please tell me changes should i made for cyclicggi in constant/polyMesh/boundary file. As i am not getting any perfect data on it otherwise i have tried for it.Please give me the directions. Thanks in advance.
August 4, 2011, 15:04 |
Santiago
Rep Power: 16 |
Hi.
I used to work with OF16 and used to used cyclic BC with the createPatch utility. Now I switched to OF16ext and I realized that the set up of cyclic BC are not longer the same as it used to. Now, I read thru the wiki http://openfoamwiki.net/index.php/Si...setup_the_case in order to set up my case. Everything is fine, but my only question is this: what do I have to specify as "zone"? My case is a simple rectangular domain where the left and right boundaries need to be periodic. I will really appreciate any help. Thanks |
August 5, 2011, 04:05 |
#7 | |
maddalena
Rep Power: 23 |
In any case, a zone is a group of points/faces/cells in your mesh that have a single specific propriety. It can be created in a wide number of way. In your case, I think you need a faceZone, which can be generated starting from the patch these faces belong to. How to create it? Type setSet on your terminal window. Hope to be clear mad |
February 2, 2012, 12:36 |
Aqua
Rep Power: 14 |
Hello, mad,
May I ask you a question please? for rotor--stater case, after regionCellsets, there are two regions created, named: cellRegion0.gz cellRegion1.gz How could I know which one is the rotor? Thank you so much! Aqua |
Display Modes | |
Cyclic Boundary Condition | Luiz Eduardo Bittencourt Sampaio (Sampaio) | OpenFOAM Running, Solving & CFD | 36 | July 2, 2012 13:23 |
[Other] StarToFoam error | Kart | OpenFOAM Meshing & Mesh Conversion | 1 | February 4, 2010 05:38 |
CheckMeshbs errors | ivanyao | OpenFOAM Running, Solving & CFD | 2 | March 11, 2009 03:34 |
[Gmsh] Import gmsh msh to Foam | adorean | OpenFOAM Meshing & Mesh Conversion | 24 | April 27, 2005 09:19 |
Multicomponent fluid | Andrea | CFX | 2 | October 11, 2004 06:12 |
