ConjugateInterHeatFoam in OF.1.6-ext..need help to fix the error!!!
Hello Guys,
I modified the conjugateHeatFoam solver in OF.1.6-ext to couple my interHeatFoam solver with solid part. I managed to compiled the solver without problem. But When I am trying to run it in a case of droplet impact on hot surface, it shows me this error: ******************* Create time Create mesh for time = 0 // using new solver syntax: T { solver PCG; preconditioner DIC; tolerance 1e-06; relTol 0; } Reading transportProperties Reading field pd Reading field alpha1 Reading field U Reading field T Reading/calculating face flux field phi Reading transportProperties Selecting incompressible transport model Newtonian Selecting incompressible transport model Newtonian Reading / calculating rho*cp Reading / calculating rho*phi*cp Reading g Calculating field g.h --> FOAM FATAL ERROR: LHS and RHS of + have different dimensions dimensions : [0 2 -2 0 0 0 0] + [1 -1 -2 0 0 0 0] From function operator+(const dimensionSet& ds1, const dimensionSet& ds2) in file dimensionSet/dimensionSet.C at line 408. FOAM aborting Aborted *********************** I think this error comes from CreateField file, So I bring it here for you guys to see if any parts of it need to be fixed. Info<< "Reading transportProperties\n" << endl; IOdictionary transportProperties ( IOobject ( "transportProperties", runTime.constant(), mesh, IOobject::MUST_READ, IOobject::NO_WRITE ) ); Info<< "Reading field pd\n" << endl; volScalarField pd ( IOobject ( "pd", runTime.timeName(), mesh, IOobject::MUST_READ, IOobject::AUTO_WRITE ), mesh ); Info<< "Reading field alpha1\n" << endl; volScalarField alpha1 ( IOobject ( "alpha1", runTime.timeName(), mesh, IOobject::MUST_READ, IOobject::AUTO_WRITE ), mesh ); Info<< "Reading field U\n" << endl; volVectorField U ( IOobject ( "U", runTime.timeName(), mesh, IOobject::MUST_READ, IOobject::AUTO_WRITE ), mesh ); Info << "Reading field T\n" << endl; volScalarField T ( IOobject ( "T", runTime.timeName(), mesh, IOobject::MUST_READ, IOobject::AUTO_WRITE ), mesh ); # include "createPhi.H" Info<< "Reading transportProperties\n" << endl; twoPhaseThermalMixture twoPhaseProperties(U, phi); const dimensionedScalar& rho1 = twoPhaseProperties.rho1(); const dimensionedScalar& rho2 = twoPhaseProperties.rho2(); const dimensionedScalar& cp1 = twoPhaseProperties.cp1(); const dimensionedScalar& cp2 = twoPhaseProperties.cp2(); // Need to store rho for ddt(rho, U) volScalarField rho ( IOobject ( "rho", runTime.timeName(), mesh, IOobject::READ_IF_PRESENT ), alpha1*rho1 + (scalar(1) - alpha1)*rho2, alpha1.boundaryField().types() ); rho.oldTime(); // Mass flux // Initialisation does not matter because rhoPhi is reset after the // alpha1 solution before it is used in the U equation. surfaceScalarField rhoPhi ( IOobject ( "rho*phi", runTime.timeName(), mesh, IOobject::NO_READ, IOobject::NO_WRITE ), rho1*phi ); // Need to store rho*Cp for ddt(rho*Cp, T) // Initialisation does not matter because rhoCp is reset after the // gamma solution before it is used in the T equation. Info<< "Reading / calculating rho*cp\n" << endl; volScalarField rhoCp ( IOobject ( "rho*Cp", runTime.timeName(), mesh, IOobject::NO_READ, IOobject::NO_WRITE ), alpha1*rho1*cp1 + (scalar(1) - alpha1)*rho2*cp2, alpha1.boundaryField().types() ); rhoCp.oldTime(); // Energy flux // Initialisation does not matter because rhoPhiCp is reset after the // gamma solution before it is used in the T equation. Info<< "Reading / calculating rho*phi*cp\n" << endl; surfaceScalarField rhoPhiCp ( IOobject ( "rho*phi*cp", runTime.timeName(), mesh, IOobject::NO_READ, IOobject::NO_WRITE ), rhoPhi*cp1 ); #include "readGravitationalAcceleration.H" Info<< "Calculating field g.h\n" << endl; volScalarField gh("gh", g & mesh.C()); surfaceScalarField ghf("ghf", g & mesh.Cf()); volScalarField p ( IOobject ( "p", runTime.timeName(), mesh, IOobject::NO_READ, IOobject::AUTO_WRITE ), pd + rho*gh ); label pdRefCell = 0; scalar pdRefValue = 0.0; setRefCell(pd, mesh.solutionDict().subDict("PISO"), pdRefCell, pdRefValue); scalar pRefValue = 0.0; if (pd.needReference()) { pRefValue = readScalar ( mesh.solutionDict().subDict("PISO").lookup("pRefVa lue") ); p += dimensionedScalar ( "p", p.dimensions(), pRefValue - getRefCellValue(p, pdRefCell) ); } // Construct interface from alpha1 distribution interfaceProperties interface(alpha1, U, twoPhaseProperties); // Construct incompressible turbulence model autoPtr<incompressible::turbulenceModel> turbulence ( incompressible::turbulenceModel::New(U, phi, twoPhaseProperties) ); # include "attachPatches.H" ****************************** Please help me to fix this problem. Thanks, Mehran |
