[Discretizer] Discretizer "Run blockmesh" issue
Old   March 9, 2012, 16:17
Default Discretizer "Run blockmesh" issue
cfdone is on a distinguished road
Hi there, I recently finished the basic openfoam cavity tutorials from the docs as well as ran a few of the examples and I feel as though I'm ready to start working with my own geometry.
To keep my first proof of concept simple I chose Discretizer as my meshing software because I found this helpful golf ball tutorial on there site: http://www.discretizer.org/node/21
I created a very simple sphere with the same dimensions as the golf ball and followed the tutorial exactly (even using the same blockmesh dimensions).
My problem is no matter what .stl file I use (I dl'd others), or how big I make my blockmesh domain, when I go to Run>>Run blockMesh it is grayed out.
As I said before, I have copied the process and dimensional values of the tutorial exactly so I'm just stumped why its not even giving me the option.
I ran blockmesh in the directory through terminal and it seemed to work but when I tried to then use snappy I received errors. Any ideas why I'm not getting the blockmesh option..or snappyhexmesh option for that matter?
Also, I am extremely new to this whole thing (installed ubuntu 3 days ago and haven't stopped messing with this stuff since). If you have any opinions on if I should even be using discretizer at all let me know. I wouldn't mind looking at alternatives.
thanks
cfdone is offline   Reply With Quote
Old   March 10, 2012, 11:49
Figured it out. I was double clicking the .sh and using "run in terminal" instead of opening terminal and ./discretizer-setup.sh. I thought using the "run in terminal" was equivalent to running the script directly but of course I was wrong.
dumb mistake please delete this thread.
[mesh manipulation] Some questions on blockMesh, decomposePar and renumberMesh Leech OpenFOAM Meshing & Mesh Conversion 19 April 5, 2019 20:21
points.gz files after run blockMesh ywem OpenFOAM Programming & Development 2 January 30, 2019 22:26
fluent issue in windows hpc pack 2012 r2 mosesHPC FLUENT 17 January 12, 2019 16:01
[blockMesh] Unable to run blockMesh for tutorial "cylinder" in OpenFoam bharadwaj1729 OpenFOAM Meshing & Mesh Conversion 4 July 22, 2018 14:03
[blockMesh] blockMesh and checkMesh with Wedges Issue michu OpenFOAM Meshing & Mesh Conversion 3 September 6, 2015 14:05
