How to decompose my case?
Hello everyone
I am simulating the flow in a pipe with an obstacle. I am trying to decompose my case to 4 and 8 parts but I fail to do that. My decomposeParDict file is like this: /*-------------------------------*- C++ -*---------------------------------*\ | ========= | | \\ / OpenFOAM | | \\ / | | \\ / The Open Source CFD Toolbox | | \\/ http://www.OpenFOAM.org | \*-------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; note "mesh decomposition control dictionary"; location "system"; object decomposeParDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // numberOfSubdomains 4; method metis; simpleCoeffs { n (1 1 4); delta 0.001; } hierarchicalCoeffs { n (1 1 1); delta 0.001; order xyz; } metisCoeffs { processorWeights ( 1 1 1 1 ); } manualCoeffs { dataFile ""; } distributed no; roots ( ); // ************************************************** *********************** // But it won't work. Could anyone tell me if there is something wrong. Thanks |
Post the error message u get, that will help to understand ur problem
Thanks for your comment.This is what I get:
Distributing points to processors Constructing processor meshes *** glibc detected *** decomposePar: malloc(): memory corruption: 0x00000000070714a0 *** ======= Backtrace: ========= /lib/libc.so.6[0x7f04154ee948] /lib/libc.so.6[0x7f04154f117c] /lib/libc.so.6(__libc_malloc+0x98)[0x7f04154f2a78] /usr/lib/libstdc++.so.6(_Znwm+0x1d)[0x7f0415d2eb9d] /usr/lib/libstdc++.so.6(_Znam+0x9)[0x7f0415d2ecd9] decomposePar(_ZN4Foam4ListIiEC1EiRKi+0x5c)[0x4ef0fc] decomposePar[0x4e96ee] decomposePar[0x447700] /lib/libc.so.6(__libc_start_main+0xe6)[0x7f04154991a6] decomposePar(_ZNK4Foam11regIOobject11writeObjectEN S_8IOstream12streamFormatENS1_13versionNumberENS1_ 15compressionTypeE+0xd1)[0x442b99] ======= Memory map: ======== 00400000-0051b000 r-xp 00000000 08:01 1286828 /home/naka/OpenFOAM/OpenFOAM-1.6.x/applications/bin/linux64GccDPOpt/decomposePar 0071b000-00723000 rw-p 0011b000 08:01 1286828 /home/naka/OpenFOAM/OpenFOAM-1.6.x/applications/bin/linux64GccDPOpt/decomposePar 02303000-0cc31000 rw-p 02303000 00:00 0 [heap] 7f03f8000000-7f03f8021000 rw-p 7f03f8000000 00:00 0 7f03f8021000-7f03fc000000 ---p 7f03f8021000 00:00 0 7f03fdab8000-7f03fdabf000 rw-p 7f03fdab8000 00:00 0 7f03fdb43000-7f03fdb81000 rw-p 7f03fdb43000 00:00 0 7f03fdc5d000-7f03fdc72000 rw-p 7f03fdc5d000 00:00 0 7f03fddc3000-7f03fddd1000 rw-p 7f03fddc3000 00:00 0 7f03fdddd000-7f03fde75000 rw-p 7f03fdddd000 00:00 0 7f03fdf44000-7f03fdf6e000 rw-p 7f03fdf44000 00:00 0 7f03fdfbe000-7f03fdfe8000 rw-p 7f03fdfbe000 00:00 0 7f03fe22a000-7f03fe278000 rw-p 7f03fe22a000 00:00 0 7f03ff19c000-7f03ff1fe000 rw-p 7f03ff19c000 00:00 0 7f03ff29c000-7f03ff2cd000 rw-p 7f03ff29c000 00:00 0 7f03ff563000-7f03ff5f6000 rw-p 7f03ff563000 00:00 0 7f04060b7000-7f0413363000 rw-p 7f04060b7000 00:00 0 7f0413363000-7f041336d000 r-xp 00000000 08:01 86573071 /lib/libnss_files-2.7.so 7f041336d000-7f041356d000 ---p 0000a000 08:01 86573071 /lib/libnss_files-2.7.so 7f041356d000-7f041356f000 rw-p 0000a000 08:01 86573071 /lib/libnss_files-2.7.so 7f041356f000-7f0413579000 r-xp 00000000 08:01 86573060 /lib/libnss_nis-2.7.so 7f0413579000-7f0413778000 ---p 0000a000 08:01 86573060 /lib/libnss_nis-2.7.so 7f0413778000-7f041377a000 rw-p 00009000 08:01 86573060 /lib/libnss_nis-2.7.so 7f041377a000-7f0413781000 r-xp 00000000 08:01 86573066 /lib/libnss_compat-2.7.so 7f0413781000-7f0413980000 ---p 00007000 08:01 86573066 /lib/libnss_compat-2.7.so 7f0413980000-7f0413982000 rw-p 00006000 08:01 86573066 /lib/libnss_compat-2.7.so 7f0413982000-7f0413984000 r-xp 00000000 08:01 86573061 /lib/libutil-2.7.so 7f0413984000-7f0413b83000 ---p 00002000 08:01 86573061 /lib/libutil-2.7.so 7f0413b83000-7f0413b85000 rw-p 00001000 08:01 86573061 /lib/libutil-2.7.so 7f0413b85000-7f0413b9a000 r-xp 00000000 08:01 86573064 /lib/libnsl-2.7.so 7f0413b9a000-7f0413d99000 ---p 00015000 08:01 86573064 /lib/libnsl-2.7.so 7f0413d99000-7f0413d9b000 rw-p 00014000 08:01 86573064 /lib/libnsl-2.7.so 7f0413d9b000-7f0413d9d000 rw-p 7f0413d9b000 00:00 0 7f0413d9d000-7f0413dee000 r-xp 00000000 08:01 1253749 /home/naka/OpenFOAM/ThirdParty-1.6/openmpi-1.3.3/platforms/linux64GccDPOpt/lib/libopen-pal.so.0.0.0 7f0413dee000-7f0413fee000 ---p 00051000 08:01 1253749 /home/naka/OpenFOAM/ThirdParty-1.6/openmpi-1.3.3/platforms/linux64GccDPOpt/lib/libopen-pal.so.0.0.0 7f0413fee000-7f0413ff1000 rw-p 00051000 08:01 1253749 /home/naka/OpenFOAM/ThirdParty-1.6/openmpi-1.3.3/platforms/linux64GccDPOpt/lib/libopen-pal.so.0.0.0 7f0413ff1000-7f0414014000 rw-p 7f0413ff1000 00:00 0 7f0414014000-7f0414058000 r-xp 00000000 08:01 1253782 /home/naka/OpenFOAM/ThirdParty-1.6/openmpi-1.3.3/platforms/linux64GccDPOpt/lib/libopen-rte.so.0.0.0 7f0414058000-7f0414257000 ---p 00044000 08:01 1253782 /home/naka/OpenFOAM/ThirdParty-1.6/openmpi-1.3.3/platforms/linux64GccDPOpt/lib/libopen-rte.so.0.0.0 7f0414257000-7f041425b000 rw-p 00043000 08:01 1253782 /home/naka/OpenFOAM/ThirdParty-1.6/openmpi-1.3.3/platforms/linux64GccDPOpt/lib/libopen-rte.so.0.0.0 7f041425b000-7f041425c000 rw-p 7f041425b000 00:00 0 7f041425c000-7f04142e2000 r-xp 00000000 08:01 1253874 /home/naka/OpenFOAM/ThirdParty-1.6/openmpi-1.3.3/platforms/linux64GccDPOpt/lib/libmpi.so.0.0.0 7f04142e2000-7f04144e2000 ---p 00086000 08:01 1253874 /home/naka/OpenFOAM/ThirdParty-1.6/openmpi-1.3.3/platforms/linux64GccDPOpt/lib/libmpi.so.0.0.0 |
I succeeded to break my case into 8 parts. :) But now the problem is that when I want to start the computations using channelFoam I get the following error:
--> FOAM FATAL IO ERROR: [0] keyword Ubar is undefined in dictionary "/home/OpenFOAM/nak/run/melika/case5/processor0/constant/transportProperties" However I can run my case with pisoFoam. :confused: |
Dear libra
use decomposePar -force to reproduce your test caes. |
Thanks everyone. My problem is solved. :)
