-   OpenFOAM (http://www.cfd-online.com/Forums/openfoam/)
-   -   fluentmeshtofoam problem (http://www.cfd-online.com/Forums/openfoam/97156-fluentmeshtofoam-problem.html)
niaz February 10, 2012 04:10
Hi Foamers:)
I want to simulate a circular cylinder. I used gambit for making mesh.
and I converted it without any problem. but during the solve, I get unusual value for Cd and Cl. I checked Aref and it is correct but I do not know what the problem is ?:confused:
plz help me:(
nimasam February 10, 2012 05:15
Hi dear Amir
two points:
1) after you import your mesh, use the command "check mesh" and look the result, is it fine?
2) u may use non hexahedral mesh, so maybe you need to use different schemes in your fvSchemes, so try different schemes in ur fvSchemes
3) for non-orthogonal you can increase the correct number in fvSolution
maybe it helps
niaz February 10, 2012 07:54
Dear nima
I have applied your suggestion but I don`t get sutiable answer
and it has still irregular Cd and Cl please check my test case (click on it) if you can?
tnx
nimasam February 10, 2012 14:59
Originally Posted by niaz (Post 343770)
Dear nima
tnx
hi i look at your case.
first: it seems everything is fine, did you check whether your simulation is converging or not?
second: Are you sure the calculation of Cd is right?
if answer to both aforementioned questions are yes :D
then i suggest first turn of the turbulence and check whether it returns reasonable result for laminar case or not
niaz February 11, 2012 03:36
Hi Nima
my case is laminar not turb.
tanx it seems that the value of residuals cannot control the loops. and after 1 iteration the pimple loop for Uy exited. I have changed my loop corrector in Fvsolution and it seems more normal value.
nimasam February 11, 2012 04:10
Hi
your simulation may be done in low velocity and it may be fall in low Reynolds number, and it is a laminar case! but i asked you to change the turbulence in the constant folder into laminar :D to omit all turbulence calculation in your case!
However im glad :D you reach a reasonable result:)
niaz February 11, 2012 04:57
Dear Nima
I had set laminar at first:D. the files are for next steps.
but it is running and it still looks good:o
tnx
