Beginner level doubts with turbulent flow simulation setup |
October 17, 2012, 08:26 |
Sagun Tripathi
Rep Power: 13 |
Hello everyone,
I am attempting to simulate multiphase turbulent flow for the first time in OpenFOAM. The two fluids present in my domain are air and water (at standard conditions) with velocity of each at inlet being 5 m/s. The domain is essentially a 2-D box of dimensions 20mx0.1mx5m (empty along 'y') with water upto a height of 2m. I have the following questions in mind as I try to simulate this situation: 1. Well, this may sound really stupid but I was thinking that since there are two fluids in the domain and flow is turbulent in each, for which fluid should parameters like k, epsilon and nu_t be calculated and assigned to the patches in the 0 folder? 2. Coming to the question of calculating these parameters, could you please tell me how to go about it? I think I calculate k and epsilon using the damBreak tutorial as a reference and nu_t using the formula give on this page: http://www.cfd-online.com/Wiki/Standard_k-epsilon_model But I'm not sure if my approach is correct. Any comments? Also, I observed that for wall patches, epsilonWallFunction and kqRWallFunction are used for epsilon and k respectively with a uniform value of 0.1. How does one arrive at this value of 0.1? 3. Also, what should be the boundary condition at the inlet for a property like k or epsilon or nu_t? Because I'm defining each one of them only for one fluid and there are two fluids present in the domain at the inlet. Sorry for barging you all with so many questions. I could really use some help here. Thanks, Sagun |
October 22, 2012, 09:56 |
Sagun Tripathi
Rep Power: 13 |
No advice? Am I being too vague too?
Display Modes | |
Problem with divergence | TDK | FLUENT | 13 | December 14, 2018 06:00 |
[snappyHexMesh] Adding layers goes wrong with SnappyHexMesh | Elise | OpenFOAM Meshing & Mesh Conversion | 1 | April 22, 2013 02:32 |
Turbulent Flow in Straight Square Duct - k-ep Validation | mcclud | STAR-CCM+ | 2 | August 7, 2012 16:56 |
Doubts on how to represent some terms for viscoelastic Flow Simulation | titio | OpenFOAM Running, Solving & CFD | 0 | February 4, 2009 07:42 |
Natural convection - Inlet boundary condition | max91 | CFX | 1 | July 29, 2008 20:28 |
