March 21, 2012, 15:46 |
K-Omega Model
pooyan
Rep Power: 14 |
Hi All,
I am simulating incompressible turbulent flow over a flat plate using OpenFoam. I am doing RANS simulation and I have selected k-omega turbulence model. I want to get the profile of U+ vs. y+ and validate it with theory. For my simulation, I do not want to use any wall function and I am using pisoFoam transiet solver available in OpenFoam. my problem is that the convergence when not using wall function is so slow and I should use a very small time step for stable solution. has anyone else faced this convergence issue before?! Besides, I have some problems with steasy solver " simpleFoam ". I use the same fvSchemes and fvSolution as one exists in tutorial for k-omega sst model, but the solution will be wrong this way. Do you have any idea how I can find the right schemes for k-omega model for steady state simulation?! I have attached the B.C for my problem. Thanks, |
March 22, 2012, 03:59 |
#2 | |
Roman Thiele
Rep Power: 20 |
The solution should be steady after a while, therefore a steady solver like simpleFoam should be sufficient, except you want to simulate developing flow. The omega wall function is not a real wall function, it is a continuous wall function. You should probably use it for omega at the wall. Did you make sure your y+<1, since you are not using any wall functions? Additionally, if you use a cell gradient towards the wall, make sure that it is very smooth, such as an expansion/growth factor of 1.1 or 1.2. k-omega-SST in OF seems to be sensitive to this.
~roman |
Display Modes | |
help for different between les model (subgrid-scale model) | liuyuxuan | FLUENT | 1 | October 2, 2009 16:25 |
Grid resolution for full-scale and down scaled model | gravis | Main CFD Forum | 0 | October 2, 2009 11:27 |
Use of k omega turbulence model | john_w | OpenFOAM Running, Solving & CFD | 2 | September 22, 2009 06:15 |
2 stage axial turbine model convergence issues | sherifkadry | CFX | 2 | September 7, 2009 21:51 |
Advanced Turbulence Modeling in Fluent, Realizable k-epsilon Model | Jonas Larsson | FLUENT | 5 | March 13, 2000 04:27 |
