October 19, 2009, 08:54 |
How to get omega fields ?
John Deas
Rep Power: 17 |
I am using OpenFOAM-1.5. I am doing RANS k-omega SST computations with a custom solver derived from simpleFoam and would like to manipulate fields of omega. In createFields.H, there is Code:
autoPtr<incompressible::RASModel> turbulence ( incompressible::RASModel::New(U, phi, laminarTransport) ); I also found the declaration of New() which did not help me much: Code:
//- Return a reference to the selected turbulence model static autoPtr<RASModel> New ( const volVectorField& U, const surfaceScalarField& phi, transportModel& transport ); |
October 19, 2009, 11:34 |
#2 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
mesh.lookupObject<volScalarField>("omega") Have a look at Doxygen to find out what that actually does |
October 19, 2009, 14:20 |
John Deas
Rep Power: 17 |
Get it. Didn't know it could be that simple.
Thanks ! |
March 20, 2012, 05:59 |
#4 | |
Arne Stahlmann
Rep Power: 17 |
I have a question/problem accessing and modifying k and omega. Using the above mentioned as simply taking Quote:
Any hints? |
March 20, 2012, 07:40 |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
March 20, 2012, 08:09 |
#6 | ||
Arne Stahlmann
Rep Power: 17 |
Hello Bernhard,
I'm sorry to say that I'm not that familiar with c++ and references/pointers. I tried to reference the object in the following ways: Quote:
I know that I definitely have to improve my c++ skills, but could you nevertheless give me the correct referencing syntax here? Thanks, Arne |
March 20, 2012, 08:58 |
#7 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
My last answer (about const_cast) was meant to be in answer of this message. I relocated it Last edited by gschaider; March 20, 2012 at 09:56. Reason: Answered wrong message |
March 20, 2012, 10:07 |
Arne Stahlmann
Rep Power: 17 |
Thanks, I already got the casting working and am currently trying to understand a bit more about it - esp. the "unwanted behavior" of a const_cast.
Incompatible fields for operation divphi Ub | vvqf | OpenFOAM Running, Solving & CFD | 4 | April 4, 2018 03:28 |
Use of k omega turbulence model | john_w | OpenFOAM Running, Solving & CFD | 2 | September 22, 2009 05:15 |
Wall function implementation K Omega SSt | cbarry | OpenFOAM | 3 | August 18, 2009 10:09 |
PostChannel | maka | OpenFOAM Post-Processing | 5 | July 22, 2009 09:15 |
Airfoil with k Omega | hoochie | OpenFOAM Running, Solving & CFD | 0 | July 3, 2007 08:10 |
