February 24, 2012, 05:04 |
BC in a volume
Samuele Z
Rep Power: 18 |
Dear all,
I am trying to set a BC in a volume and not on a surface. In other words, I want that a certain volume in my domain has a certain fixed temperature. Of course, this condition is much stronger than imposing the temperature on the surface, isn't it? Do you have an idea if it is possible (if yes, could you tell me how, please) do what I would like to do? Thanks a lot, Samuele |
February 24, 2012, 06:27 |
Laurens Van Dyck
You could modify your solver by adding some lines that checks the position of a cell
If that cell is then in the region you want it overwrite the calculated value with your own fixed value. |
February 24, 2012, 06:30 |
Samuele Z
Rep Power: 18 |
Actually, I am reading about the setValues function that is available in OpenFOAM.
In fact I know the label of the cells I want to fix the value in. Do you know something about this? Thanks a lot, Samuele |
February 24, 2012, 09:17 |
Samuele Z
Rep Power: 18 |
Also, I forgot to write that I am running OF 2.0 and am using the solver buoyantSimpleFoam.
Furthermore, I can not und which is the righ file to edit. I checked this thread, too. But I can't find the right file to edit. Could you help? Thanks a lot, Samuele |
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 17:22 |
On the damBreak4phaseFine cases | paean | OpenFOAM Running, Solving & CFD | 0 | November 14, 2008 21:14 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
