runtime is not in enumeration
--> FOAM FATAL IO ERROR:
runtime is not in enumeration: 5 ( adjustableRunTime clockTime cpuTime runTime timeStep ) Can anybody tell me how to solve this problem? |
Greetings kebi112358,
Best regards, Bruno |
Thank you so much!Problem solved!
adjustTablerunTime is not in enumeration: 5 ( adjustableRunTime clockTime cpuTime runTime timeStep ) file: C:/OpenFOAM/20.09/cygwin64/opt/OpenFOAM/OpenFOAM-dev/tutorials/socavacion/ system/controlDict/writeControl at line 30. From function Enum Foam::NamedEnum<Enum, nEnum>::read(Foam::Istream&) const [with Enum = Foam::Time::writeControl; unsigned int nEnum = 5] in file lnInclude/NamedEnum.C at line 69. FOAM exiting Can anybody tell me how to solve this problem? |
If you read wyldckat's post carefully, you will recognize your mistake.
