Home > Forums > OpenFOAM
Incomplete geometry in snappyHexMesh
Old   March 1, 2012, 05:59
Default Incomplete geometry in snappyHexMesh
anon_a is on a distinguished road
Hi there!
I have been trying to use sHM in my geometry for the past couple of days.
The geometry can be considered (in a simplified way) as two large vessels connected through a tiny orifice.
The problem is that the orifice is so small that the geometry is considered "disconnected", so I end up with a mesh for the volume containing the "locationInMesh" point only. I have tried refining the features to level 6 and I also added refinement regions (levels 4-6) around the orifice but the problem remains.
I think that the point where this is done in sHM is the following:
Removing mesh beyond surface intersections
Found point (1.015 0.201 0.001) in cell 50762 in global region 1 out of 4 regions.
Keeping all cells in region 1 containing point (1.015 0.201 0.001)
Selected for keeping : 775563 cells.
Right before that point, there were 1270916 cells.
I would appreciate any help in this. I could try doing it in another program but I would like to have the option of sHM too.
anon_a is offline   Reply With Quote
Old   March 4, 2012, 10:43
calim_cfd's Avatar
mauricio
calim_cfd is on a distinguished road
hi
when you have mesh problems it's always nice to upload some pics..
not sure i can help you.. i'll just highlight a few points maybe they will help you
-to use shm you need first to have a consistent volume created with blockMesh and a 2d stl(or sth else) boundary. By consistent i mean you need to get the vertices and faces ordering right, else the "location point in mesh" will fail.. there's a topic regarding this issues in these forums.. you may wanna look it up. Else you can check the user's guide either at the website or within OF installation
-try loading your boundary mesh in paraview(or other software) and check for possible errors. look for free edges, they should point you the possible leakage of your mesh!
-and it doesn't matter whether your orifice is 1e-25mē small, smh you "see it" and work it accordingly
in sum: check the volume from where shm will create the wet domain for consistency/dimensions/interferences and the boundary stl mesh for leakage...
can't help you more at this point
good luck
Best Regards
/calim
"Elune will grant us the strength"
calim_cfd is offline   Reply With Quote
Old   March 12, 2012, 05:30
Thanks for your answer and sorry for my delayed post.
I managed to include my complete geometry about a week ago using a feature edge refinement level 7 and modifying my blockMesh. My bounding box has a size of 1.4m, my orifice is around 0.0001m thick and when my blockMesh cells (110 in that direction) are refined 7 times, they reach around the appropriate size and are finally kept by sHM.
Thread Tools
Trackbacks are On
GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM 300 October 29, 2014 19:00
snappyHexMesh keeping internal geometry ThibaudB OpenFOAM Native Meshers: snappyHexMesh and Others 9 March 22, 2012 16:59
SnappyHexMesh meshes inside and outside of an STL geometry villier OpenFOAM Mesh Utilities 17 June 15, 2010 19:51
snappyHexMesh geometry Kristianur OpenFOAM Native Meshers: snappyHexMesh and Others 16 April 4, 2010 10:14
vitual _ real deneb FLUENT 3 January 22, 2007 05:31
