Home > Forums > OpenFOAM
swak4Foam to calculate bubble velocity
Like Tree1Likes
  • 1 Post By gschaider
Old   March 1, 2012, 12:28
Default swak4Foam to calculate bubble velocity
Nima Sam
nimasam is on a distinguished road
Send a message via Yahoo to nimasam
hi former
i guess, it should be possible to access a bubble velocity with swak4Foam
but i dont know how the procedure can be?
the procedure should be like that:
1) select all cells with alpha < 0.5
2) calculate the gravity center in each time step
any comment or suggestion?
nimasam is offline   Reply With Quote
Old   March 1, 2012, 14:10
Assistant Moderator
Bernhard Gschaider
Originally Posted by nimasam View Post
hi former
Why use a cutoff? that way you're going to get jumps in your result. Something like
"(pos()*vol()*(1-alpha1))/sum(vol()*(1-alpha1))"
(with an accumulation sum) might give you the center of the "non-fluid".Have a look at my presentation from the last workshop (you'll find it on the swak4Foam-page on the Wiki). Slide 76 has a similar application.
BTW: if you're interested in the velocity of the liquid interface then you might want to have a look at slide 155 where it s demonstrated how to calculate that with sampledSurfaces
nimasam likes this.
bubble, swak4foam
Thread Tools
Trackbacks are On
Calculate velocity components from shear stress Arnoldinho OpenFOAM Running, Solving & CFD 0 August 29, 2011 12:07
how to compute relative velocity from absolute? spk Main CFD Forum 3 July 9, 2010 08:42
velocity of air Robert Main CFD Forum 4 January 22, 2007 18:42
How to calculate Drift Velocity Kumar FLUENT 0 November 15, 2004 08:10
How to calculate Drift Velocity Kumar FLUENT 0 November 12, 2004 05:45
