Home > Forums > OpenFOAM
swak4foam
Like Tree2Likes
Old   May 24, 2012, 06:46
Tom Schmitz
Zuixy is on a distinguished road
Thank you. You helped me a lot. I think i understand now how it works.
Unfortunately it doesn't work at all with potentialWaveFoam. I try to figure out why and will post it, if i succeed.
Zuixy is offline   Reply With Quote
Old   December 15, 2012, 05:43
Default swak4foam
  #22
Sahar
S.Jafari is on a distinguished road
hi
im new in openFoam too. im trying to simulate falling droplet. for having a set of results i use swak4foam to get the information of field deitalls. i wrote the function for calculating mass center of falling drop. now i want to find some other variables in each time step (such as velocity) using the mass center that i found as i said.
explaining more:
i wrote function for calculating mass center in each step time (x)
now i want to use x to calculate velocity in this formulation: v=[x(2)-x(1)]/deltaT
how can i match these function in control dict?
S.Jafari is offline   Reply With Quote
Old   December 16, 2012, 20:32
Assistant Moderator
Bernhard Gschaider
Originally Posted by S.Jafari View Post
hi
explaining more:
One possibility would be to use a storedVariable (this is just a sketch):
variables (
  "newPos= <however you calculate your mass centern>;"
  "velocity=(newPos-oldPos)/deltaT();"
  "oldPos=newPos;"
expression "velocity";
storedVariables (
     name oldPos;
    initialValue "vector(0,0,0)";
Initial value is the tricky part because that might cause a velocity "jump" in the beginning
Or you can always load the positions you calculated into a spreadsheet and do the calculation there
S.Jafari likes this.
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   December 17, 2012, 02:39
Nima Samkhaniani
nimasam is on a distinguished road
missed a }
thank you for your reply
variables ( "newPos= <however you calculate your mass centern>;" "velocity=(newPos-oldPos)/deltaT();" "oldPos=newPos;" ); expression "velocity"; storedVariables ( { name oldPos; initialValue "vector(0,0,0)";
Telegram channel (https://telegram.me/openfoam4Iranian)
My Weblog (http://openfoam.blogfa.com/)
Training Course on OpenFOAM at (http://www.isme.ir/)
nimasam is offline   Reply With Quote
Old   December 17, 2012, 05:16
Assistant Moderator
Bernhard Gschaider
Originally Posted by nimasam View Post
missed a }
That's what I mean with "just a sketch"
nimasam likes this.
Old   December 20, 2012, 05:53
Sahar
thank you so much for the answer
Old   August 4, 2013, 05:57
Mohammad Bahreini
mecman is on a distinguished road
Hi all
i want use of FunkySetFields for may case in OpenFoam2.1.1,i instal swak4Foam for this version witout problem,i made FunkySetFieldsDict for my case and after when i run that i see this problem
--> FOAM FATAL ERROR:
funkySetFields: time/latestTime option is required
From function main()
in file funkySetFields.C at line 641.
FOAM exiting
what is my mistake?
mecman is offline   Reply With Quote
Old   August 4, 2013, 06:08
Nima Samkhaniani
you should enter time argument
funkySetFields -time 0
Old   August 4, 2013, 11:40
Mohammad Bahreini
thnax nima...i found it...
Thread Tools
Trackbacks are On
swak4foam building problem GGerber OpenFOAM Installation 54 April 24, 2015 16:02
groovyBC and funkySetFields married and got a kid named swak4Foam gschaider OpenFOAM 164 January 13, 2015 03:52
swak4Foam compilation problem ganeshv OpenFOAM Running, Solving & CFD 5 November 11, 2011 17:39
Swak4foam: get the value of a field in the neighbour cell of a patch face miles_davis OpenFOAM Pre-Processing 7 October 5, 2011 11:57
swak4Foam for faceZones andrea.pasquali OpenFOAM 3 August 30, 2011 11:24
