Time varying write interval in controlDict
Old   August 23, 2011, 05:41
Post Time varying write interval in controlDict
Sabin Ceuca
sabin.ceuca is on a distinguished road
Dear foam'ers,
does anybody know how to write the requested fields on a varying period of time rather than a constant interval?
I need a higher frequency after a specific time and don't want to get into troubles with my IT admin while overloading the cluster
Is there something for
writeInterval   0.05;
similar to a variable BC?
Patch1
  type         timeVaryingUniformFixedValue;
  fileName     "fileToBeRead";
  outOfBounds  clamp;
Regards,
sabin
sabin.ceuca is offline   Reply With Quote
Old   March 7, 2012, 04:04
Martin Söder
Soder is on a distinguished road
This would be very helpful for me aswell.
Does anyone know how to do it?
Regards
Martin
Soder is offline   Reply With Quote
Old   March 7, 2012, 04:24
Olivier
olivierG is on a distinguished road
hello,
If you use the 2.1 version, there is a new control for timing the writing
(see http://www.openfoam.org/version2.1.0...me-control.php)
regards,
olivier
olivierG is offline   Reply With Quote
Old   March 7, 2012, 05:02
Paulo Bufacchi
Bufacchi is on a distinguished road
If you don't use the 2.1 version, you can try changing the parameter manually in controlDict by the time you need the change.
I was running a case and by the end of the run (I checked the log file), I changed the endTime parameter and the case understood my change in controlDict, what made me realize that controlDict is read upon changes in it. So, if you don't mind changing the writeInterval manually, this is one way to make it happen.
Regards,
Paulo
Bufacchi is offline   Reply With Quote
controldict, output data, writeinterval
mesh file for flow over a circular cylinder Ardalan Main CFD Forum 7 December 15, 2020 13:06
Full pipe 3D using icoFoam cyberbrain OpenFOAM 4 March 16, 2011 09:20
FSI with time interval remeshing ? realanony87 CFX 8 September 17, 2010 12:04
calculation diverge after continue to run zhajingjing OpenFOAM 0 April 28, 2010 04:35
why did my time interval set for output nouse? ShFlow FLOW-3D 2 January 11, 2009 20:25
